icom radio
icubob(at)newnorth.net
PostPosted: Fri Jan 12, 2007 2:40 pm    Post subject: icom radio Reply with quote
hi all, i am getting started on the wiring of my ic-a200 icom radio. i would use an 18 ga wire to the ''power '' pin and an 18 ga wire to the ''ground'' pin of the radio . the enclosed wiring instructions say this.........POWER CABLE WIRING...
use 2 pairs of 18 ga wires for power and power grounding.
what the heck? the diagram is very simple and if it werent for the printed statement above i would just proceed. anyone wired one of these radios? what do their instructions mean? thanks for any info.
    bob noffs
larry(at)macsmachine.com
PostPosted: Fri Jan 12, 2007 3:12 pm    Post subject: icom radio Reply with quote
Hi Bob,
The Molex connector has multiple grounds and there are also power inputs
at B, M and 11.
I'm sure that's all they're referring to. I remember going thru the
same ?? when wiring the A200.
Larry McFarland -601HDS at www.macsmachine.com
bob noffs
wrmaxwell(at)bigpond.com
PostPosted: Fri Jan 12, 2007 3:18 pm    Post subject: icom radio Reply with quote
The instructions are simply aiming to ensure that the radio can access sufficient current once you hit PTT, Bob. A single 18 ga wire would presumably run the risk of supplying inadequate current. I have wired up several A200 but have used a single run of conventional multistrand twin (figure Cool DC supply cable from my ham radio toolkit, good for at least 8 Amps.
Bill
nuckollsr(at)cox.net
PostPosted: Fri Jan 12, 2007 3:57 pm    Post subject: icom radio Reply with quote
I'm mystified about this trend in the newer radios
to suggest not only multiple power and ground leads but
the suggested sizes are very generous too. For a radio
that draws a couple of amps, 18AWG wire is certainly
plenty big for the job.
Looking over the installation instructions, the only
rationale I can deduce for multiple wires is redundancy.
Their choice of I/O connectors for this radio is highly
suspect. We quit using board edge fingers and large-area,
low-pressure connectors in new products years ago where
I work. MUCH better that they would choose to use at least
a d-sub connector. Given the poor history of the card-edge
fingers in aircraft, I suppose someone might have thought
they were increasing system reliability with multiple
power wires . . . but that idea works only if there are
no other single wires that would disable the radio.
As to oversized wire, I can't guess. I've been a great
fan of Icom Ham equipment for years. I've not heard
any complaints about the A200 performance but their
packaging leaves something to be desired.
My suggestion is that single, 20AWG power and ground
feeders will suffice and probably be more reliable
because this gage actually FITS the pins you're trying
to crimp onto the wires.
< with experiment. >
< --Lawrence M. Krauss >
harvey4(at)earthlink.net
PostPosted: Fri Jan 12, 2007 4:26 pm    Post subject: icom radio Reply with quote
Bob....I got held up by the same stupid instructions. Just wire it as you would think - one wire for ground, one for power.
Neil
bob noffs
PostPosted: Fri Jan 12, 2007 7:18 pm    Post subject: icom radio Reply with quote
hi all, thanks to everyone that responded to my question. after getting thru the confusing written instructions the rest should be easy!
    bob noffs
