Deems Davis
Posted: Mon Jan 08, 2007 2:02 pm Post subject: Source for Laser/WaterJet cutting |
I'm looking for a source that can do laser or water jet cutting of some
subpanels for my instrument panel. Since I'm using a 'non-standard'
panel it's not one of those supported on epanelbuilder. I have the
capability to produce and send AutoCad compatible files. anybody know of
a source?
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
mike(at)cleavelandtool.co Guest
Posted: Mon Jan 08, 2007 2:23 pm Post subject: Source for Laser/WaterJet cutting |
Witte Industries in South Dakota is a new RV10 Builder... Ask for Michael. I understand they do 1 off parts.
You may have luck with Precision H2O in Spokane, WA also, but they are more geared toward production.
Mike
On 1/8/07, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:[quote] --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
a source?
Deems Davis # 406
Cleaveland Aircraft Tool
515-432-6794
www.cleavelandtool.com [quote][b]
noel(at)blueskyaviation.n Guest
Posted: Mon Jan 08, 2007 2:27 pm Post subject: Source for Laser/WaterJet cutting |
Yes Deems, I have water-jet cutting available to me just had a panel cut
for an RV-7 we are building E Also I did my labeling using Solid Works came
out Fantastic!!! Best panel I have ever done!!!
Noel
mail2web - Check your email from the web at
http://mail2web Ecom/ E
121.68 KB |
274 Time(s) |
127.05 KB |
266 Time(s) |
142.8 KB |
285 Time(s) |
jwik(at)crary.com Guest
Posted: Mon Jan 08, 2007 2:55 pm Post subject: Source for Laser/WaterJet cutting |
I know of a small one person shop. I know she laser's primarily
acrylics but is accustomed to very small quantity requirements and likes
the small niche markets.
I'll ask on her experience and willingness for aluminum (I'm sure her
laser has the wattage needed) and AutoCad in the next day or two unless
someone comes up with something better. I've forgotten where you are,
I'm in Fergus Falls MN.
I'm not even close to this stage so I'd need to know approximate size
and gauge of the parts.
Deems Davis wrote:
some subpanels for my instrument panel. Since I'm using a
'non-standard' panel it's not one of those supported on epanelbuilder.
I have the capability to produce and send AutoCad compatible files.
anybody know of a source?
Deems Davis # 406
apilot2(at)gmail.com Guest
Posted: Mon Jan 08, 2007 3:25 pm Post subject: Source for Laser/WaterJet cutting |
Deems, Pacific Southwest Avionics at Stellar does it, although when I
wanted a couple holes enlarged to 3 ATI size they weren't interested,
too small a job. He is mostly into redoing entire panels on certified
planes. http://www.psavionics.com/
On 1/8/07, Deems Davis <deemsdavis(at)cox.net> wrote:
a source?
Deems Davis # 406
jesse(at)itecusa.org Guest
Posted: Mon Jan 08, 2007 4:21 pm Post subject: Source for Laser/WaterJet cutting |
Double R Manufacturing in Ocala, FL does it. They have done work for us.
They price is good, but they have to be convinced a little bit to do such a
small job. You can get them at www.doublermfg.com.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
david555(at)cox.net Guest
Posted: Mon Jan 08, 2007 5:06 pm Post subject: Source for Laser/WaterJet cutting |
Deems, I have a water jet and a CNC router. Call me (at) 757 236 5110 and I'll
discuss the pros and cons of the approaches to cutting the panel with each
of these machines. I have cut test panels out of scrap High pressure
laminate in order to tweak the panel layout prior to cutting the final
panel. I created a frame designed with four subpanels so that I could remove
one section without removing the others. Good Luck David O Boone 40138
mikedoble(at)wi.rr.com Guest
Posted: Mon Jan 08, 2007 5:54 pm Post subject: Source for Laser/WaterJet cutting |
Deems - I have a guy I work with here that has a fab shop with a water jet
machine. He can convert AutoCAD to his system and cut away...
Send me a file offline with the thickness and I'll pass it on for a quote.
Mike
Waiting on my EMP kit.....Shipped today though!!!
ddddsp1(at)juno.com Guest
Posted: Mon Jan 08, 2007 10:06 pm Post subject: Source for Laser/WaterJet cutting |
Noel,
Can Solid Works do labeling on TEXTURED painted panels? Love to talk to you about it. You have a number I can call you at?
Dean 40449
________________________________________________________________________
FREE Reminder Service - NEW from AmericanGreetings.com
Click HERE and never forget a Birthday or Anniversary again!
Posted: Tue Jan 09, 2007 7:29 am Post subject: Source for Laser/WaterJet cutting |
Solid works just created the "art work" for the labiling. using trexure I
think (the people on the list may know better) you will want silk
screeaning witch will need the same Art work as I created for labeling.
Blue Sky Aviation, Inc.
406-538-6574
www.blueskyaviation.net
http://mail2web.com/ .
Deems Davis
Posted: Tue Jan 09, 2007 3:31 pm Post subject: Source for Laser/WaterJet cutting |
Thanks to all who provided leads and contact info re this topic I've got
a few more days work to finish off the CAD files, but I think I've got
enough leads to get something worked out.
THANKS Again
Deems Davis # 406
http://deemsrv10.com/ -
waiting on engine mount fix to hang engine
armywrights(at)adelphia.n Guest
Posted: Tue Jan 09, 2007 8:15 pm Post subject: Source for Laser/WaterJet cutting |
Deems, what went wrong with your mount, or do you have a close tolerance a
la Tim O?
Rob Wright
#392
Engine mount on horizon
