bakerocb
Posted: Mon Jan 08, 2007 8:50 am Post subject: GRT GPS TSO |
1/8/2006
Hello Bret, You quote GRT as writing: "The new RAIM-equipped version
provides integrity
monitoring and 5 updates per second to meet the requirements of IFR GPS TSO
C129 and C146."
This sounds like some subtle weasel wording to me. A piece of equipment
either meets the full TSO requirements and is marked TSO compliant or it is
not TSO'd.
The manufacturer does not get to cherry pick certain standards within the
TSO, or its references, just meet certain standards, and then mark the
equipment as TSO'd.
Most manufacturers who have gone to the expense and effort of obtaining TSO
approval for a piece of equipment are very eager to make that approval and
marking very evident to any prospective purchaser.
OC -- The best investment we will ever make is in gathering knowledge.
On 5 Jan 2007, at 22:05, Bret Smith wrote:
Quote: | <smithhb(at)tds.net>
See http://www.grtavionics.com/documents/Horizon%20System%20Flyer.pdf
"The addition of the internal GPS receiver eliminates the need for an
external
GPS, or may be used as a backup to your primary GPS. Available in two
versions. The standard WAAS GPS module is perfect for VFR use, or
as backup
to an external GPS. The new RAIM-equipped version provides integrity
GPS
TSO C129 and C146."
Standard WAAS GPS Receiver with antenna $450
RAIM-Equipped WAAS GPS Receiver with antenna $750
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Jan 08, 2007 9:35 am Post subject: GRT GPS TSO |
"A piece of equipment either meets the full TSO requirements and is marked
TSO compliant or it is not TSO'd."
True, but not necessarily the point...
In some instances the regs require that a piece of equipment MUST MEET TSO
STANDARDS. This is the case with transponders.
In other instances the equipment MUST BE TSO'd. This is the case with IFR
GPS units.
You mentioned, "...manufacturers who have gone to the expense and effort of
obtaining TSO approval for a piece of equipment..."
If simply meeting the TSO requirements is adequate, why should a
manufacturer "go to the expense and effort"?
bakerocb
Posted: Tue Jan 09, 2007 9:49 am Post subject: GRT GPS TSO |
1/9/2007
Hello Bret, Continuing our dialogue.
1) You wrote: "If I get called out on the carpet for a non-TSO'd GPS, what
would they say
about my non-TSO'd TruTrak AP, Ray Allen trim system, GRT AHRS/Magnetometer,
HID homegrown landing lights, LED nav lights, etc?"
I believe that IFR / Night equipment for ABEA's falls into one of the
following categories:
1A) Purely optional equipment installed at the desire of the builder with no
existing regulatory requirement.
1B) Equipment required by FAR 91.205 (b), (c), and (d) because of wording in
the aircraft's Operating Limitations.
1C) Equipment required by FAR 91.205 (b), (c), and (d) because of wording in
the aircraft's Operating Limitation that is identified as needing to be
"approved" in those paragraphs.
1D) Equipment required by other paragraphs within the FAR's that would apply
to all aircraft, both type certificated with standard airworthiness
certificates and ABEA's with special airworthiness certificates.
1E) Equipment required by the AIM for certain types of operations that would
apply to all aircraft, both type certificated with standard airworthiness
2) Your non-TSO'd TruTrak AP, Ray Allen trim system, GRT AHRS/Magnetometer,
HID homegrown landing lights and other equipment of that ilk would fall into
category 1A above and should generate no FAA criticism because it is not
TSO'd.
3) Your LED nav (position) lights would fall into category 1C above. See
91.205 (c), (2). If your initial ABEA airworthiness inspector issues the
aircraft a special airworthiness certificate he has, by implication,
"approved" those position lights in the name of the FAA Administrator (see
FAR 1.1). If he refuses to issue the certificate and demands to see TSO
markings because the regulations require it, he is wrong. If he refuses to
issue the certificate and demands to see either TSO markings or test results
showing that the lights meet FAR Part 23 position light standards, that is
within his prerogative as an inspector.
4) If you had only a non TSO'd GPS aboard and performed a specific operation
that the AIM required a TSO approved GPS for then you would not be in
compliance with 1E and may be subject to a charge of careless or reckless
operation (see FAR 91.13).
5) You wrote: "My understanding is that before flight into the national air
system, under
IFR, the pilot/builder of the OBAM aircraft must determine and document via
flight testing that the aircraft and it's systems meet the requirements for
IFR flight, night flight, etc."
This is certainly common sense. I would be interested in seeing some
regulatory basis for the above. The sources that I am aware of that cover
specific ABEA requirements for IFR and night flight are the Operating
Limitations for that aircraft and the references contained therein including
FAR 91.319.
FAR 91.319 (d), (2) reads "Operate under VFR day only, unless otherwise
specifically authorized by the Administrator."
The Operating Limitations will contain these words: "After completion of
Phase I flight testing, unless appropriately equipped for night and/or
instrument flight in accordance with 91.205, this aircraft is to be operated
under VFR, day only."
If the aircraft meets the "appropriately equipped" criteria it is considerd
by the FAA to have been given the Administrator's specific authorization to
fly at night and under IFR. What we have been discussing is what constitutes
"appropriately equipped".**
**PS: It is interesting to note that if the aircraft is given authorization
for aerobatic flight in the Operating Limitations that those maneuvers must
be specifically tested and documented in the aircraft's logbook.
PPS: You wrote: "This is a really interesting topic and I truly respect your
opinions.
It is evident you have a good understanding of these issues."
I appreciate your kind words.
bakerocb
Posted: Tue Jan 09, 2007 10:52 am Post subject: GRT GPS TSO |
1/9/2007
Hello Bill,
1) You wrote: " In some instances the regs require that a piece of equipment
MUST MEET TSO
STANDARDS. This is the case with transponders. In other instances the
equipment MUST BE TSO'd. This is the case with IFR GPS units."
Both TSO-145A and TSO-C146A dealing with IFR GPS units contain the following
paragraph (MPS means Minimum Performance Standards):
"g. Deviations. The FAA has provisions for using alternative or equivalent
means of compliance to the criteria set forth in the MPS of this TSO.
Applicants invoking these provisions shall demonstrate that an equivalent
level of safety is maintained and shall apply for a deviation per 14 CFR §
21.609"
2) TSO-C129a is an older TSO dealing with IFR GPS units and does not contain
specific alternate compliance words within it as is the case with more
current FAA TSO's, but here is a quote from the current AIM, note the use of
the word "equivalent":
"g. Equipment and Database Requirements.
1. Authorization to fly approaches under IFR using GPS avionics systems
requires that:
(a) A pilot use GPS avionics with TSO- C129, or equivalent, authorization in
class A1, B1, B3, C1, or C3; and......"
3) You wrote: "If simply meeting the TSO requirements is adequate, why
should a
manufacturer "go to the expense and effort"?"
My point exactly. Simply meeting some of the TSO requirements is not
adequate to fulfill the intent of the FAA TSO requirements.
GRT implies that they are completely fulfilling the FAA TSO intent by
writing: "The new RAIM-equipped version provides integrity monitoring and 5
updates per second to meet the requirements of IFR GPS TSO C129 and C146."
The equipment must either be TSO'd in accordance with the provisions of FAR
Part 21 Subpart O or FAA deviation approval from the TSO in accordance with
paragraph 21.609 must be obtained. Neither one of these are easy actions to
take and there is no indication in the GRT statement posted that either
action has been taken. Hence my suspicion of misleading weasel wording.
Time: 09:35:15 AM PST US
Subject: RE: GRT GPS TSO
GPS units.
bakerocb
Posted: Tue Jan 09, 2007 2:13 pm Post subject: GRT GPS TSO |
1/9/2007
Hello Bret:
1) You wrote: "As you can see, the FAA has left a wide loophole with the
phrase "or equivalent"."
The FAA has learned from experience that locking technical requirements in
bureaucratic documents in concrete can come back to bite them when
technology comes up with a better mouse trap that was not envisioned in the
document. So now-a-days they caveat their TSO's with a statement to the
effect that "if you can do it just as good, but maybe a little differently
we are willing to listen to your proposal."
The process for a request to deviate is described in FAR 21.609 and the
loophole is not that wide. You might find that entire FAR 21 Subpart O
interesting reading. You can see that obtaining TSO approval and
manufacturing in accordance with that approval can be burdensome.**
2) You wrote: "It appears that, from my understanding, a GPS used for IFR
navigation must meet the minimum standard of RTCA/DO-208 in order to meet
the standard of TSO-C129 in order to be approved for IFR navigation."
I agree. Also realize that there are other documents referenced in TSO-C129a
that may contain standards that the unit may have to meet. And the FAA may
chose to not incorporate all provisions of referenced documents into the
TSO. Some TSO's are absolutely infuriating -- they say nothing of substance
technically themselves, but instead reference several documents (such as SAE
documents) that cost a bunch of money for just three or four pages.
3) You wrote: "Problem is, I don't see where the FAA requires the GPS to be
"certified".
I agree. The words theFAA uses are "authorization (to perfom IFR operations)
requires equipment approved IAW TSO -C129" (version C129a is the current
version). Lawyers may not agree with me, but I bet the Garmin marketing
people looked at the FAA terminology of "authorization" and "approved" and
said "certified sounds better to us".
4) You wrote: "I may be confused here but it seems that when Garmin states
their GNS430 is "IFR Approach Certified", they are only stating that this
receiver meets the requirements of TSO-C129."
I agree -- and also meeting all the pertinent references to TSO-C129a and
permitting the FAA oversight of Garmin's production of the GNS 430. (See FAR
21.615).
In addition now Garmin is stating that the GNS 430W meets all the
requirements of TSO 146a.
**PS: I worked with Lance Turk, founder of Vision Microsystems, on a special
size oil temperature probe for my TCM engine. He would not make the probe
for me because it would be non TSO'd and he did not want to contaminate his
FAA TSO approved production line. I wound up buying an empty brass
temperature probe body from Westach and sending it to Lance so that he could
have one of his technicians epoxy one of the Vision Microsystems special oil
temperature probe sensors into that brass body's cavity. Works like a charm.
khorton01(at)rogers.com Guest
Posted: Tue Jan 09, 2007 3:06 pm Post subject: GRT GPS TSO |
On 9 Jan 2007, at 17:10, <bakerocb(at)cox.net> wrote:
states their GNS430 is "IFR Approach Certified", they are only
stating that this receiver meets the requirements of TSO-C129."
C129a and permitting the FAA oversight of Garmin's production of
the GNS 430. (See FAR 21.615).
One more thing - if Garmin says that their GNS430 is "IFR Approach
Certified", it also means that it has been found by the FAA to be
capable of being installed to meet the guidelines in Advisory
Circular 20-138A Airworthiness Approval of Global Navigation
Satellite System (GNSS) Equipment.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
