Narco ADF with RG-62 Antenna
mprather(at)spro.net
PostPosted: Sun Jan 07, 2007 5:52 pm    Post subject: Narco ADF with RG-62 Antenna Reply with quote
Hey Listers,
My airplane has a Narco 141 ADF (which works only marginally). I was
under the panel inspecting things and noticed that it's wired with RG-62
coax. I didn't recognize that number so I looked it up. I found that
it's 93ohm impedance cable. Does anybody know if that's the right stuff
for this ADF? I had thought 50ohm was the defacto standard for avionics.
I am wondering if having the wrong cable might be causing the substandard
performance..
Other question.. Does anyone have a diagnostic manual or install manual
for this ADF?
Matt-
nuckollsr(at)cox.net
PostPosted: Sun Jan 07, 2007 6:35 pm    Post subject: Narco ADF with RG-62 Antenna Reply with quote
At 06:49 PM 1/7/2007 -0700, you wrote:
Hey Listers,
performance..
for this ADF?
Yeah, that's the right stuff. It's a special lo-capacity
coax used in low frequency radio receivers. Not easy to find
and not fun to work with either as I recall but it's been
many moons.
The only data I have on it is the pinout diagrams I've published
at:
http://www.aeroelectric.com/Installation_Data/Narco_140-141_ADF.pdf
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Sun Jan 07, 2007 7:44 pm    Post subject: Narco ADF with RG-62 Antenna Reply with quote
Okee doke.. The pinout is interesting, but doesn't have everything I was
looking for.
Thanks anyway (times two).
Matt-
<nuckollsr(at)cox.net>
> <mprather(at)spro.net>
>Hey Listers,
>performance..
>for this ADF?
many moons.
at:
