"Broken and Garbled" (Additional data)
nuckollsr(at)cox.net
PostPosted: Wed Jan 03, 2007 9:25 am    Post subject: "Broken and Garbled" (Additional data) Reply with quote
At 08:10 AM 1/3/2007 -0600, you wrote:
One comment on these radios, take the advertised range and cut it in half
at best.
Yeah, the itty-bitty hand-helds are victims of way too
much marketing hype. I've used them vehicle to vehicle
solid out to 1/2 mile and open line-of-sight to about a
mile. One pair I had was good to a couple hundred yards
vehicle to vehicle.
However, for the tasks to which I've applied these radios
a range of a few feet has been sufficient.
Mark Phillips in TN
PostPosted: Wed Jan 03, 2007 9:04 pm    Post subject: "Broken and Garbled" (Additional data) Reply with quote
In a message dated 01/03/2007 11:28:30 AM Central Standard Time, nuckollsr(at)cox.net writes:
Took some PRS radios on a ski trip to Whistler/Blackcomb a few years back and talked to the kids high on the mountain from the rental unit- maybe 5 or 6 miles, but line-of-sight for sure. These things did work pretty darn well regardless of where the units were on either mountain. Also recall a couple of stranded climbers rescued several years ago because they were able to contact some kid 15 or 20 miles away...
Mark do not archive
From The PossumWorks...
Speedy11(at)aol.com
PostPosted: Fri Jan 05, 2007 8:40 pm    Post subject: "Broken and Garbled" (Additional data) Reply with quote
Well, that is dramatically different than the advertising. The ones I saw advertised ranges that varied between 5 and 18 miles.
Stan
at best.
vehicle to vehicle.
