icubob(at)newnorth.net Guest
Posted: Wed Jan 03, 2007 3:41 am Post subject: solder |
hi all, i understand the advantages of a 63/37 blend of solder . is 60/40 ''almost as good'' or is there some reason that makes is a much poorer choice? it is easily available while 63/37 is quite a bit less frequent on the store shelves.
bob noffs
nuckollsr(at)cox.net Guest
Posted: Wed Jan 03, 2007 6:04 am Post subject: solder |
At 05:38 AM 1/3/2007 -0600, you wrote:
Quote: | hi all, i understand the advantages of a 63/37 blend of solder . is 60/40
the store shelves.
60/40 is an adequate substitute for 63/37 and as you've
noted, is much easier to find. It will be just fine
for your purposes.
willslau(at)alumni.rice.e Guest
Posted: Wed Jan 03, 2007 6:13 am Post subject: solder |
Yes, it's almost as good, but it does have a small temperature range where it has a plastic state. If you wiggle even slightly as it cools through this range, you'll have a substandard joint. If everthing is up on the bench and solidly held, it wouldn't be a problem. Obviously lots of things get successfully soldered with the 60/40, but I just ordered a one pound spool of 63/37 from Digikey when I couldn't find any locally. Unless I drastically increase my soldering, it'll last me the rest of my life and then some, and it maximizes my chances of each joint being as it should be.
William Slaughter
RV-8 QB
Almost finished enough sheetmetal to be able to run a wire for a change!
