CJohnston(at)popsound.com Guest
Posted: Tue Jan 02, 2007 6:24 pm Post subject: riveting forward fuse panel area |
hey all -
i have many questions!!! I'm now in week 2 of my vacation - been home working on the airplane the whole time... I've just finished the flap actuation section, and I'm into the panel area. I haven't really finalized my panel layout, or even which type of panel (aluminum or fiberglass) I'm going with. Question - Am I a fool to rivet the upper forward fuselage section to the aircraft? Is it really that tough to install the panel if you've done this already? I won't be able to move on if i don't rivet it on, but I don't want to hose myself.
also, in this section, you're supposed to rivet on some hinges for the cowl. I'm using camlocs, but I haven't received them yet. should I just leave the rivets out of the firewall flange for now? I'm kinda lost here... it seems like you need the engine on before you can mount the camlocs right? or do you mount the receptacles now, and do the rest when you're doing the cowl? what the heck?
thanks in advance!
cj
#40410
(con)fuse(d)
jesse(at)itecusa.org Guest
Posted: Tue Jan 02, 2007 6:57 pm Post subject: riveting forward fuse panel area |
Chris,
I imagine for some things it is a lot easier to install the panel, or at
least get a lot of the wires and systems in, before installing the upper fwd
fuse, but a lot of people, including me, just install it and run everything
with it in, especially those that don't want to invest in the instruments
before they need to. There is a lot you can do without it, like installing
the cabin top (if you haven't already), but there certain things that just
can't be done with it off. It is even possible to fit the cowling without
doing a final install, but it does require a couple of rivets. Fitting the
cowling does require an engine (or at least most of one), though. I would
recommend at least doing some of the sub-panel modifications before
installing it, which will help a lot. You won't be hosed if you go ahead
and put it in, IMHO. I would say, on the Camloc issue, that you really
can't rivet the glareshield skin to the firewall without the Camloc stuff,
unless you just rivet on a piece of aluminum and mount the Camlocs in that,
but I seem to remember seeing a special Camloc receptacle thing that rivets
on there for those who want it. In this case, you need those first, but you
could put a couple of "keeper" rivets along the firewall and go ahead and
rivet down the sides.
Hope this helps.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
LarryRosen
Posted: Tue Jan 02, 2007 6:59 pm Post subject: riveting forward fuse panel area |
I am holding off riveting the forward fuse panel area. I still have it
clecoed in place. I fit the canopy, fit the doors, I just installed the
overhead in the canopy, I am working on wiring the plane, I want to get
as many of the firewall penetrations completed, put the strips in for
the camlocs, and then just before I complete the final install of the
canopy, that is when I will rivet in the forward fuse plane. It is much
easier working on the plane with the forward panel removable and the
canopy off.
Larry Rosen
#356
Chris Johnston wrote:
| Quote: | hey all -
thanks in advance!
cj
#40410
(con)fuse(d)
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim(at)MyRV10.com Guest
Posted: Tue Jan 02, 2007 7:00 pm Post subject: riveting forward fuse panel area |
Hi Chris,
You should be able to actually probably even attach the fiberglass
top before you finally rivet on the upper forward fuse. I was
able to slide mine in place with the canopy in place. I would
install it as late as possible, but even with it installed,
you should still be able to do plenty of panel work. Just a
few things may not be quite as easy. Not a huge deal.
Same thing with the firewall flange up there. Just cleco it and
do all that when you finally do that upper forward fuse. Basically,
you should be able to just press on until you just can't do
much more without riveting that stuff. I didn't do camlocs, but
you probably can mount the recepticle side anytime, if you
can see where you want them to go. The trick is, you'll want the
engine on to do the cowl, and you'll want the cowl trimmed to
place the camlocs. So you probably can't do them unless you
can model after someone elses and know close to where they'll
be. I'd just wait if I were you.
There's so darn much stuff to do on the kit that I'd just plug
away at everything that you obviously can do, and procrastinate
on everything you can that seals it all up.
| Quote: | hey all -
to hose myself.
thanks in advance!
cj #40410 (con)fuse(d)
Posted: Tue Jan 02, 2007 7:12 pm Post subject: riveting forward fuse panel area |
Great point about the subpanel, Jesse. Chris, he's right
about one thing. If you're going to chop up and reinforce
those panel ribs on the sides, you'll want to do that before
you mount the forward fuse on the fuselage....and you'll want
to make sure you have them cut far enough to clear the
instruments you're planning on.
Jesse Saint wrote:
Chris,
Hope this helps.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Wed Jan 03, 2007 7:01 am Post subject: riveting forward fuse panel area |
Why not rivit it in place but leave the top skin off. Thats what I did and
it sure made it easy to do all the wiring and mounting of the behind the
panel stuff. My panel is removeable, so the last thing will be to install
it. It's already been in and out a half dozen times.
Ted French C-FXCS reserved
pre-paint prep
winmail.dat |
1.05 KB |
329 Time(s) |
_________________ Ted French
RV-10 fuselage |
