Back-Up Battery
trigo(at)mail.telepac.pt
PostPosted: Tue Jan 02, 2007 10:31 am    Post subject: Back-Up Battery Reply with quote
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Now that there's a bit more time to consider the questions,
let's do a quick review of the techniques and rationale for
installing "backup" batteries:
When you use the phrase "backup" there is an implied
notion that what ever power supply is normally expected
to carry some load aboard the aircraft suffers a low order
of confidence that it will always be there to do its job.
The classic idea of a "backup" power source has been
with us since day-one. The engine drive generator or
alternator is primary, the battery is a secondary energy
source.
With the popularity of all-electric panels on the
rise,
I must say that my airplane will be double-electrically-dependant. I have a
Subaru electrically-dependant engine and an all-electric panel (well, I'll
still have 2 "steam-gauges": Altimeter and Airspeed Indicator). Since I have
no possibility of installing a second alternator or generator, and the
engine factory installation calls for 2 (equal) batteries, no wonder I am
thinking about a 3rd (small battery), also fuelled by the possibility of
having to put some wheight in the butt.
Opposite to your opinion, I think that, if I have to put some "dead" lead
down there, why not put some "live" lead (aka battery), which will do both
jobs? I believe it's a very good return on investment, like you love to say.
There was some concern about "ground loops" . . .
Ground loops are not created by the mis-application of
a battery ground. Ground loops are the mis-application
of grounds in TWO systems . . . the antagonist and
victim systems. For the most part, ground loops are
avoided by careful crafting of the wiring for potential
victims . . . so while battery charge/discharge
currents for the small stand-by battery under discussion
are a potential source for miniscule noise currents
carried on the battery's ground path, good grounding
practice for potential victims makes the ground-loop
question moot. So yes, the battery can share a ground
to the airframe with all other non-victim devices
that might also ground to that location.
OK, thanks. I think I already got the "ground loop" thing.
Carlos
pilot4pay
PostPosted: Tue Jan 02, 2007 1:53 pm    Post subject: Back-Up Battery Reply with quote
Subject: Re: Back-Up Battery
<trigo(at)mail.telepac.pt>
source.
Maybe it needs to be presented in another way.
Carlos, the issues that (I think) Bob is trying to address is not so much
about dead vs. live weight but the utility of having a battery that is so
small in capacity to be of marginal "real" value. The battery will require
periodic maintenance, so you will need reasonable access. Will that access
then require additional modifications to the plans/airframe. Now, again look
at your return on the modification. Add to that the associated circuitry and
wiring.
Is this mounting engineering task worthy of 4.5 Ah?
Recently I was researching another issue regarding electrical code and
aircraft hangars and (can't remember if it was in FARs or NEC) came across
some rules that prohibit charging aircraft batteries installed in the
airframe. (that finally answered a nagging question I'd always had as to why
my external power connector was electrically isolated from the ships
battery).
The "back-up" system installed in the 182 is a substantial system. I don't
recall the exact AH capacity of the battery but it is physically at least as
large as the primary battery under the cowl. Therefore there is an access
panel on the tail for the purpose of servicing the battery and avionics rack
there. So the system in the Cessna is a substantial piece of engineering,
but also quite massive.
It appears from your descriptions that the battery would actually end up
being just added system AH capacity, not a true "back-up electrical power
source". The Cessna system will power the entire avionics system for a solid
45 min. There is a test circuit that is part of every preflight, in order to
verify that the system is charged and available (another piece of
engineering that a reliable back-up would reasonably require).
Now for the few pounds of weight needed for balance, does it still seem
reasonable to jump these hurdles? I guess there still are personal
considerations involved, an aversion to unitaskers, or having something that
is just weight on an airplane where dead weight just seems like a waste of
useful load. But honestly, YOUR efforts would be better spent on
construction of your aircraft. This is not sarcasm, or ridicule, but a
discussion of the merits of an effort. Back up systems are great, but they
entail a level of engineering/cost/maintenance that needs consideration
before proceeding.
Believe me, in my profession(machine tool manufacturing), we constantly look
for more efficiency and utility in our equipment, and in that quest I've
come up with a lot of ideas, not all of which stood up under scrutiny.
Fortunately there were others to look at my ideas and point out factors I
may not have been aware of, or looked at from another viewpoint. I'm
grateful that I was saved the embarrassment of having spent time and MONEY
on features of little practical use.
Bob is correct in that all of the contactors/protection needs to be
considered in your endeavor, some are regulatory as well as for your safety.
Craig Smith
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
PostPosted: Tue Jan 02, 2007 4:08 pm    Post subject: Back-Up Battery Reply with quote
The battery will require periodic maintenance, so you will need reasonable
> access. Will that access then require additional modifications to the
plans/airframe.
Not at all. It will be installed on the tail "deck" of the RV-9A, between
the 2 halfs of the horizontal stabilizer. I don't know if you are familiar
with it, but that zone is covered by a fiberglass fairing which makes the
aerodynamic transition between the H.S. and the vertical stabilizer, and is
attached with some 12 screws easily removable.
Add to that the associated circuitry and wiring.
Very simple. Since I was "authorized" by the experts-on-duty to connect the
(-) terminal to the local ground, I will only have to squeeze in an AWG#14
wire from the tail to the instrument panel (in fact, I already did, in case
I decide for this battery), and connect it there to the avionics I decide to
have back-up power, and to the main battery, through a Diode, to take
charge.
I don't know how to do the exact calculations, but I suppose that it will be
enough to power the Comm Radio, the Transponder, the EFIS and the Auto-pilot
(or some of these 4, depending on the pilot's decision) for the 45 min you
mentioned. Well maybe I should go for something a little larger (6 Ah ?),
providing it stays within the C.G. limits
source".
Not so, as you can see from the above descriptions. My idea is to use this
battery always at the start-up procedure, to initially power the EFIS (to
keep the battery used and to control its voltage), and from then, remain as
a pure back-up only for the avionics, in case of alternator-Off and the
engine-ignition-fuel pumps running only on the Main and/or Aux batteries.
Above answered
Yes, it does to me. Does it already seem to you (no sarcasm here, I mean,
after my explanations) ?
Don't worry, I'm not spending my efforts on this. Today I was riveting my
canopy
Back up systems are great, but they entail a level of
engineering/cost/maintenance that needs consideration before
proceeding.
That's exactly the reason why I brought the subject to this knowleadgeble
forum ....
safety.
What I did was to install a 10 or 15A (I can't remember which) fuse on the
tail, at the positive wire, right "after" the (+) future battery terminal.
Isn't that enough protection?
Carlos
PostPosted: Tue Jan 02, 2007 5:12 pm    Post subject: Back-Up Battery Reply with quote
> source.
> rise,
a Subaru electrically-dependant engine and an all-electric panel (well,
I'll still have 2 "steam-gauges": Altimeter and Airspeed Indicator). Since
I have no possibility of installing a second alternator or generator, and
the engine factory installation calls for 2 (equal) batteries, no wonder I
am thinking about a 3rd (small battery), also fuelled by the possibility
of having to put some wheight in the butt.
If you already have two batteries, how about moving one of them aft
to satisfy W&B requirements without having to add all the overhead
for installing and maintaining a third battery?
Only you can make the judgement as to whether the proposed, third,
itty-bitty battery offers a good return. But after years of
rubbing elbows with folks in the business, I know what reactions
we'd get if we add one more line item to the maintenance list
for continued air-worthiness . . . especially in view of the
relatively small benefits offered by a 4.5 a.h. device.
This is why I wanted to discuss it in more detail. I like it
if everyone monitoring the List understands all the ramifications
for such an installation and understand further that I would
recommend avoiding such an installation until all the alternatives
and cost of ownership issues have been evaluated. I.e., is there
a simpler way to get the job done?
klehman(at)albedo.net
PostPosted: Tue Jan 02, 2007 5:49 pm    Post subject: Back-Up Battery Reply with quote
> will be enough to power the Comm Radio, the Transponder, the EFIS and
> the Auto-pilot (or some of these 4, depending on the pilot's decision)
> for the 45 min you mentioned. Well maybe I should go for something a
> little larger (6 Ah ?), providing it stays within the C.G. limits
Carlos
As a guess off the top of my head, consider that if you intend to draw
say 4 amps out of a 4.5 AH battery then you will only get about 2 AH or
30 minutes with a new fully charged battery. A battery has high internal
losses when working that hard. There are discharge charts available for
many batteries that will give you a better approximation.
If your main batteries are say 16 AH then they won't run the run the
engine for much more than 30 min. each if you are drawing nearly 15
amps. You'd likely do a bit better with the batteries paralled. Adding
another 4 amps to those main batteries will only shorten the engine
running by a few minutes. You might get more benefit per lb. from upping
one of the main batteries to 20 AH than from adding another 4.5 AH battery.
However your weight and balance is certainly another consideration if
not your main concern with this. Yet another
important consideration will be system management though. If you
are ever in the situation where the battery capacity is that critical I
would urge you to make the system as easy to operate as possible and
ideally zero management. I would not want to have to manage 3 batteries
in the heat of the moment... Sizing the third battery so that it always
runs your critical instruments (E bus) and will outlast the engine might
be worth considering.
Also there are many ways to power a second generator on a subaru if you
decide you want more electrical capacity. I've even seen accessories
driven off a small flat belt from the prop shaft. I used two small
multi-v belts off the oem pulley on my ej22 and also I directly drive a
vacuum pump off the pulley end of a camshaft.
Ken
Ed Anderson
PostPosted: Tue Jan 02, 2007 6:02 pm    Post subject: Back-Up Battery Reply with quote
Having flown an "electric dependent" Mazda rotary powered installation since
1998, I understand the concern about not having enough electrons along if
the electron pump stops working. However, I do agree with Bob concerning
the very marginal benefit vs complexity of a third small battery. I started
out with a modification of one of Bob's excellent wiring diagrams and ended
up with an 60 amp alternator (with abnormal voltage - too high or too low
warning )with the crowbar circuit tripper for the alternator and a
voltmeter. I started with two 25 AH Concord RCG batteries totaling 44 lbs!.
I could have probably stayed airborn on just the starter motor {:>)
After flying for 4 years with this combination and only using the secondary
battery to help crank on cold mornings, I now fly my "all-electric" with one
680 Odyssey battery (which I swap out every 2 years regardless of its
condition). I have shed 30 lbs of battery weight and I believe that on the
east coast that the 30-45 minutes the 17 AH Odyssey will give me at minimum
current drain configuration should enable me to easily find a suitable
airport. My minimum current drain configuration is all but engine
electronics off, GPS on battery, radio on. I pull a CB so only one set of
spark plugs are firing (the rotary has two per chamber), only one pair of
fuel injectors are firing (plenty to keep me airborn) and only one fuel pump
is running.
I have learned the hard way that weight is the performance killer and have
spent years slowly getting my aircraft's weight reduced toward a norm for my
bird. I would strongly suggest following Bob's suggestion of moving one of
your two batteries toward the rear for the W&B and forgetting the third
battery.
FWIW
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.dmack.net/mazda/index.html
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
