Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Jan 01, 2007 8:58 am Post subject: Silicone Uniwrap tape |
Tom,
It is a bit difficult to make a good wrap around an electrical connector
with the silicone tape but it will tolerate the temperatures under the
engine cowl. The high temp stability is 400 F with short term to 600 F. The
tape will bond with itself and will necessate cuttiing it from the connector
if you need to remove it later. I have successfully used it to wrap wire
bundles such as EGT leads and other leads under the cowl.
Dale Ensing
Quote: | If one forgets to put a piece of heat shrink on a connector or terminal,
is there any other sort of tape or other insulator that is good to use in
its place? Particularly under the cowl, where it gets hot.
I am particularly interested in the Uniwrap silicone tape. They claim it
is weather resistant, has no adhesive (sticks to itself) and heat
resistant, though I can't find just how heat resistant it is. It may
have other uses too, such as restraining a wire from chafing, etc. Looks
like interesting stuff.
Tom S., RV-6A
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
