c-section leveling
naumuk(at)alltel.net
PostPosted: Sat Dec 30, 2006 9:43 am    Post subject: c-section leveling Reply with quote
All-
Don't need no stinkin' lasers. Thanks to Larry Mac for a different approach.
Note the blazingly brilliant finish on the TOP of the c-section.
I'm almost on track.1 hr to finish leveling the c-section, then 2 hrs cleaning the black crud and hairballs out of my shop from polishing. From there, I start polishing the rear fuse skins. If everything goes right, I (Clean the new black crud and hairballs from my shop, then) assemble the rear fuse sometime tomorrow (If my bonnets hold out after 3 washings).
In case you haven't noticed, I'm a prodigious poster a couple of times a year. Two days from now, I go back to the grind and don't have an extra day off until April. It's been fun while it lasted.
Bill Naumuk
HDS Fuselage
Townville, Pa
 Filesize:  33.92 KB
 Viewed:  174 Time(s)
