Z14 contactor(s) circuit question
rtitsworth
PostPosted: Tue Dec 26, 2006 7:08 pm    Post subject: Z14 contactor(s) circuit question Reply with quote
Bob, etal,
I noticed on the Z-14 schematic there is not a breaker, nor fuse, nor
fuseable link, anywhere along the current path from the battery(s) to the
battery contactor master switch(es) on the panel (and then to ground).
A short (wire failed to ground) between the contactor and the switch would
just keep the contactor closed (the same as the switch being on) and thus no
risk of additional damage, fire, etc. (due to the resistance of the
contactor coil).
However, if the contactor itself failed internally and shorted the power
terminal to the switch/coil terminal, it seems the 22AWG switch wire would
fry.
Perhaps the likelihood of that is so remote as to outweigh the complexity/
risk of an additional component in the circuit. However, breakers and fuses
are pretty reliable and with Z14 there is Bus#2 and the cross tie, which
could be used if the #1 master breaker/fuse failed and caused the #1
contactor to open (and/or vise versa).
Thus, I am thinking of perhaps putting a fuse(s) in-line with the master
switch(es). Thoughts?
Rick
klehman(at)albedo.net
PostPosted: Wed Dec 27, 2006 5:51 am    Post subject: Z14 contactor(s) circuit question Reply with quote
Hi Rick
FWIW I believe I added a fuse link (about two inches of 26awg wire
inside glass sphaghetti as per the B&C kit) anywhere that I reduced
wiring size to 22awg from a heavier than 5 amp protected circuit. As you
say, the risk of the specific failure that you describe has to be very
low so I think a fuse link makes more sense than a fuse. They don't
really take up space and I would expect no corrosion or maintanance
issues within a couple of lifetimes...
Ken
rtitsworth wrote:
Bob, etal,
contactor coil).
fry.
Rick
nuckollsr(at)cox.net
PostPosted: Wed Dec 27, 2006 12:10 pm    Post subject: Z14 contactor(s) circuit question Reply with quote
At 10:06 PM 12/26/2006 -0500, you wrote:
<rtitsworth(at)mindspring.com>
Bob, etal,
contactor coil).
fry.
Your hypothesized failure is somewhere on the same
order of probability as being hit by a meteor while
on short final. The published configurations have been
evaluated MANY times for nearly a century but have
remained unchanged. I can see no return on investment
for adding this feature.
< with experiment. >
< --Lawrence M. Krauss >
