Daisy-Chaining Stereo Inputs
mchamberlain@runbox.com
PostPosted: Sun Dec 24, 2006 4:44 am    Post subject: Daisy-Chaining Stereo Inputs Reply with quote
Hi All and Happy Christmas!
I am trying to get stereo input from multiple sources (MP3, GPS, Traffic etc.) in to my FlightCom 403 intercom. I figured it might work by just "daisy-chaining" them together but if I have more than one plugged it at once I get some sort of nasty feedback. Is there some sort of device I need in between them so they can't "see" each other?
Thanks for your help,
Mark - N234C
Flying - 48 hours
Rv-7 (234C Res)
Engine
nuckollsr(at)cox.net
PostPosted: Sun Dec 24, 2006 9:39 am    Post subject: Daisy-Chaining Stereo Inputs Reply with quote
The problem is not so much one of "feedback" as it is
for "loading". Each source, while not supplying energy
to the signal stream presents a potential for being a load.
this means that while one source is being used, it sees multiple
loads that may affect both signal intensity and frequency
response. MUCH better that you use an isolation (mixing) amplifier
if you want to use multiple sources simultaneously or a simple
two-pole, three-position switch (like miniature 4-pole, on-on-on
switch) for selecting each source one at a time.
However, you won't damage anything with the daisy chaining
experiment. Give it a try. It might prove satisfactory to your
needs . . . it's just not the best we know how to do.
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Sun Dec 24, 2006 12:01 pm    Post subject: Daisy-Chaining Stereo Inputs Reply with quote
I forgot to add. There's a brief discussion of multiple source
audio mixing in the current update chapter to the 'Connection
which you're free to download at:
http://aeroelectric.com/articles/Rev11/18Audio_R11.pdf
ceengland(at)bellsouth.ne
PostPosted: Sun Dec 24, 2006 1:38 pm    Post subject: Daisy-Chaining Stereo Inputs Reply with quote
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Date: 2006/12/24 Sun AM 11:37:39 CST
Subject: Re: Daisy-Chaining Stereo Inputs
It might be worthwhile to ask what he means by 'daisychaining'. The most common meaning in my world is plugging one device into the next, then that device into the next, etc. If he's doing that, there might easily be 'feedback' issues depending on how each device handles 'ins' & 'outs'.
Charlie
