question about Vans Starter Relay
rv8builder(at)earthlink.n
PostPosted: Mon Jan 30, 2006 2:28 pm    Post subject: question about Vans Starter Relay Reply with quote
Sometime ago, I purchased a starter relay from Vans Aircraft.
Now that I am ready to start the wiring of my RV-8, I need to know how the terminals on the relay labeled "S" and "I" should be wired?
Thanks in advance,
Dale Ellis
Greer, SC
chaztuna(at)adelphia.net
PostPosted: Mon Jan 30, 2006 3:06 pm    Post subject: question about Vans Starter Relay Reply with quote
Dale,
The relay you mention is actually a Ford starter relay. S stands for
START and I stands for IGNITION BYPASS. To engage the relay, you need to
apply 14 volts to the S terminal. For our use, the I terminal isn't needed.
However, you could run a 22 AWG wire from the I terminal up to a "starter
engaged" enunciator lamp on the instrument panel. Run the other lead from
this lamp to your single point ground block. The lamp would warn you if the
relay ever stuck "on".
Charlie Kuss
Thanks in advance,
Dale Ellis
Greer, SC
nuckollsr(at)cox.net
PostPosted: Mon Jan 30, 2006 5:25 pm    Post subject: question about Vans Starter Relay Reply with quote
A similar relay and descriptions of the terminals
is illustrated at:
http://www.aeroelectric.com/Pictures/Contactors/s702wire.jpg
Dale,
Charlie Kuss
<rv8builder(at)earthlink.net>
>Thanks in advance,
>Dale Ellis
>Greer, SC
< with experiment. >
< --Lawrence M. Krauss >
