smoking rivets
noel(at)blueskyaviation.n
PostPosted: Sat Dec 16, 2006 4:52 pm    Post subject: smoking rivets Reply with quote
Here are some drawings I did quickly to help picture acidental
countersinking of the base metal E
Noel
mail2web - Check your email from the web at
http://mail2web Ecom/ E
sheet_metal_class1.PDF
 Filename:  sheet_metal_class1.PDF
 Filesize:  189.82 KB
 Downloaded:  189 Time(s)
sheet_metal_class.PDF
 Filename:  sheet_metal_class.PDF
 Filesize:  42.51 KB
 Downloaded:  228 Time(s)
KiloPapa
PostPosted: Tue Dec 19, 2006 12:13 am    Post subject: smoking rivets Reply with quote
Nice visual with the drawings. Thanks for taking the time.
Kevin
40494
tail/empennage
Kevin
40494
rwshooter(at)cox.net
PostPosted: Tue Dec 19, 2006 3:54 am    Post subject: smoking rivets Reply with quote
Hey Noel,
Could you resend those rivet drawings. I couldn't open due to "corrupted"
file..
Thanks.
Robb
192RL....reserved
PostPosted: Tue Dec 19, 2006 7:36 am    Post subject: smoking rivets Reply with quote
Try these, if you can't open them someone else with greater computer skills
than I will have to intervene.
Noel
sheet_metal_class.pdf
 Filename:  sheet_metal_class.pdf
 Filesize:  42.51 KB
 Downloaded:  201 Time(s)
sheet_metal_class1.pdf
 Filename:  sheet_metal_class1.pdf
 Filesize:  189.82 KB
 Downloaded:  216 Time(s)
