JAYRES(at)entergy.com Guest
Posted: Mon Jan 30, 2006 6:43 am Post subject: Engine problems |
Many thanks to all who provided feedback in helping me identify my engine
problem. I finally had time of the past weekend to try some of the many
suggestions. And as most of you who responded guessed, it was an induction
leak.
I connected the discharge side of a shop vac to the bottom of the carb
intake, duct taped it up the best I could and turn the vac on. Then began
spraying soapy water around the induction components.
I immediately began to see bubbles forming at the right rear induction tube
near the engine. Turns out that the steel tube that inserts into the
aluminum cast oil pan was loose and leaking.
Again, many thanks to everyone who helped point me to the problem.
Jimmy Ayres
RV6A - flying
RV7A - building
