archermj(at)swbell.net Guest
Posted: Wed Dec 06, 2006 6:49 pm Post subject: Jabiru Starter contactor and solenoid |
I have a Jabiru 3300 and have a 702-1 starter contactor from B&C. Looking at Z-20, from aeroelectric, they are running the 4 AWG wire to the starter solenoid. It looks like the "solenoid" supplied by Jabiru is really just another contactor. It is wired and works the same as the 702-1 but with out the diode. If I hook it up as depicted in Z-20 all I will be doing is to energize the coil on the Jabiru supplied solenoid with the 4 AWG wire from the 702-1. It sure looks to me that all I will be doing is putting two contactors in series. I am not sure of the value in this. I am considering just leaving off the Jabiru solenoid and connecting the 702-1 directly to the starter.
Is this smart or is there something I am missing?
Matt
www.zodiacxl.com
nuckollsr(at)cox.net Guest
Posted: Tue Dec 12, 2006 5:17 am Post subject: Jabiru Starter contactor and solenoid |
To: <aeroelectric-list(at)matronics.com>
Subject: Jabiru Starter contactor and solenoid
First, the Z-figures are ARCHITECTURE drawings and not intended
to dictate wire sizes, breaker/fuse sizes, or equipment choices.
They are simply foundations upon which your own system details
are laid.
The apparent "dual starter contactors" anomaly you've cited
is discussed in the article at:
http://aeroelectric.com/articles/strtctr.pdf
Depending on what features are specific to the starter supplied
with your Jabiru, the specifics illustrated in Z-20 may not
apply.
If your existing starter is fitted with the hi-inrush, pinion
engagement mechanism typical of B&C starters, then the "dual
contactor" philosophy -or- the Starter Boost relay shown
in Z-22 is recommended to enhance the service life of your
starter push button or switch.
< with experiment. >
< --Lawrence M. Krauss >
