jcorner(at)shaw.ca Guest
Posted: Tue Dec 05, 2006 9:14 pm Post subject: 0-235 vs Turbo Subaru |
This is maybe a problem that most of you wish you had..... and to
many the answer might be very obvious.
I have 1 each of the above two engines, one I purchased and the other
I received on a debt owing. For this question assume that installed
cost is about the same.
Installed weights are about the same...... and one of these engines
is going into a Kitfox Model 5, I just can't seem to make a final
decision and stick with it.
The Sube has more power 150+ vs 115 for the Lyc
The Lyc has a longer proven history of reliability, and perhaps a
little easier to install and maintain.
The S5 Kitfox will be equipped for night flying, i don't expect any
hard IFR, floats may come later.
One week I am convinced that I will install the Sube, next the Lyc.
Have to make up my mind very soon, pre-cover inspection coming right up.
Which one should I install? Comments appreciated.
Jim
PS: I currently fly a Model 2, 582 s/n 575 just over 1100 hrs.
Glenn Horne
Posted: Wed Dec 06, 2006 5:36 am Post subject: 0-235 vs Turbo Subaru |
The Lyc. No question about it. There are only two engine to fly behind.Lyc.
7 Cont.
GG
barefootpilot(at)comcast. Guest
Posted: Wed Dec 06, 2006 5:38 am Post subject: 0-235 vs Turbo Subaru |
Jim,
I have the Lycoming on a model 5 and have been very happy with it. Lots of
torque to turn a big prop which gives great take off and climb performance.
Cruise speed is good also (130 mph at 5.2 gph) For floats I think the Lyc
might be the better choice.
The nice things about the subie are that it can burn auto gas and you can
install an inflight adjustable prop. For my taste though, the Lycoming is a
much simpler setup with fewer things to go wrong and you can get parts and
service on it anywhere.
good luck,
Cliff
Jim
eskflyer(at)lvcisp.com Guest
Posted: Wed Dec 06, 2006 6:14 am Post subject: 0-235 vs Turbo Subaru |
I dont know who brain washed you but , your wrong . There are many engines
to fly behind . They are all mechanical and will break at some point . That
said I have flown behind 2 strokes and never had a engine out . I have
flown behind continentals and have had rods thrown threw the case . I have
flown behind subbies and never had a problem . ahve flown behind Lycomings
and had mags fail . HMMMMM whats the better engine , each to there own i
guess.
John Perry
ruebd(at)skymail.csus.edu Guest
Posted: Wed Dec 06, 2006 8:41 am Post subject: 0-235 vs Turbo Subaru |
Jim:
Direct drive and a single cooling system, maintainability
'anywhere' would favor the Lycoming. Assuming that both engines are in
good serviceable condition, I know which one I would rather be flying
behind when, say approximately 100 miles west of Denver at 13,500 ft.
(for a brief period). I would definitely vote for the Lycoming at that
time.
The "real ones" are often criticized for being behind the times,
but the truth is that they are tried and true, and have the advantage of
being designed from the ground up as aircraft engines, and have
benefited from years of improvement, and advances of material science.
Since aircraft engines experience a very different operational profile
than car engines, putting out 100% power at every takeoff, and then
65-75% continuously thereafter, until descent and landing, all of their
parts were designed with that operation profile in mind, from the
crankshaft to the valves. They are often compared to tractor engines,
and with good reason, since a tractor also needs to put out a high
percentage of its power continuously. Tractor engines are, of course,
heavy, so they are not a good choice for airplanes.
The "real ones" have been developed to produce the most power at
the least weight, retaining the highest reliability possible. System
simplicity is one of the ways that this is achieved.
Now, we Kitfox pilots are flying airplanes that are in the class
called "experimental", so this opens the door for trying different
things, which is the decision that you are of course struggling with.
I would try to make the choice depending on where my flights are likely
to be carried out, just how much night flight you anticipate, and how
much you will 'enjoy' the systems complication associated with the
Subbie.
Also try to remember how the different engines and especially
their major components look to you comparatively whenever you have seen
them displayed at shows. Here is where I rest my case for the "real
ones", but if your anticipated flight profiles give you the opportunity
to experiment with your power unit, then use the car engine, and join
the ranks of those who are in a continuous mode of solving carburetor
problems, cooling leaks, gearbox issues, and head gasket concerns,
ignition system questions, oil leaks, not to mention the stress factors
that arise due to the loads that are passed through an engine that was
designed to be connected to a bell housing/transmission, and not to have
the gyro loads of a propeller induced into its 'block' and then taken on
through to a mounting system that was not the one considered by its
designer. Your type 5 is well able to do mild aerobatics, so if you
anticipate doing any of these, then you would want to be sure your power
unit will not get sick before you do.
Yes, I know, some of the most famous military craft have liquid
cooling, and a geared propeller. They also were designed from the
ground up as aircraft, and military ones at that, so I contend that they
make a poor comparison or justification for those systems in a civilian
light plane.
Whichever you choose, do install the "help me Joe" kit offered
by John McBean, this will do wonders to refine the control system, and
keep the back pressure needed under control on approaches, since you
will have an airplane that tends to be nose heavy, and the elevator has
no aero-counter force designed in. This spring coupling is designed
for the model 5's thru 7's, and in my opinion is an essential
improvement when heavier engines are used.
Duane Rueb, N24ZM
Fox5flyer Guest
Posted: Wed Dec 06, 2006 10:52 am Post subject: 0-235 vs Turbo Subaru |
Good narrative Duane. Even though I'm a Soob driver I agree with all of it.
However, if it weren't for us experimenters, even the Lycosaurs' and Conts
wouldn't be around today.
It sounds as if you must have installed the spring coupler in 24ZM. Can you
be more specific on how it works, what is included with the kit, and what it
costs?
Deke
Jim:
time.
Subbie.
light plane.
Duane Rueb, N24ZM
Posted: Wed Dec 06, 2006 11:50 am Post subject: 0-235 vs Turbo Subaru |
Deke, and list:
Yes, I did install the "help me Joe" kit into N24ZM. It was
priced at $85 when I purchased it, and it couples the elevator to the
flaps, and installs behind the seat. The only thing that might
improve the kit would be a suggestion as to how to stretch the fairly
stiff (for human strength, and the position available if working through
the seat access panels that are in my plane) spring.
What I did with Milts help was to first put the spring in a
bench vice and stretch it just enough to insert a (approx 3/4") nylon
strap between some coils near the end that we would be pulling from,
then with two people working, with one pulling the straps, and the other
guiding the sprint to the front hook point.
If the airplane has no access panels in the seat back, you will
have to remove the seat, which will make attaching the spring easier, so
you may not feel you need to use a strap, but it worked so well, that it
may still be the best approach.
Take note of the elevator droop you have before you install this
kit, and after, and you will see quite a difference. The elevator no
longer droops, and will stay level. The real change is when the flaps
are put in as on an approach, where the spring now helps you with the
extra back pressure/trim now needed. On mine, the trim can now
compensate for this, allowing neutral or very near neutral stick back
pressure with one notch of flap at an approach speed of 60-65mph
indicated. With full flap, some additional back pressure is needed, but
much less than before.
I think that this kit results in a better control system feel
all around, too, not just on approaches.
Duane
Glenn Horne
Posted: Wed Dec 06, 2006 11:57 am Post subject: 0-235 vs Turbo Subaru |
You are right. Each to their own.
For me there are only two. Lyc. & Cont.
GG
dave
Posted: Wed Dec 06, 2006 12:04 pm Post subject: 0-235 vs Turbo Subaru |
Don't forget the franklins........
and yes Rotax a dominant player.
I would take a 912 over a soob anyday for a floatplane especially.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Thu Dec 07, 2006 6:57 pm Post subject: 0-235 vs Turbo Subaru |
Thanks to all that responded to my question. Since this is a very
personnel decision I was not surprised that most replies were
off-list. Most people are not willing to get involved in a potential
long debate and I certainly respect that.
The result of it all is that I have decided to go with the
Lycosaurus..... ten years ago, approaching 60 rather than 70 my
decision I think would have been the other way. All those extra
horses sure look tempting!
Thanks again.
Jim
