Radial engines in general
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
n395v
PostPosted: Mon Jan 30, 2006 11:07 am    Post subject: Radial engines in general Reply with quote
I know nothing about radials, absolutely nothing.
What are their advantages/disadvantages.
Where is the cam, do they have a corrosion problem?
Why an odd number of cylinders?
Is the hydraulic lock issue as big as some make it seem?
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Milt
moose174(at)gmail.com
PostPosted: Mon Jan 30, 2006 4:04 pm    Post subject: Radial engines in general Reply with quote
Hi Milt.
Being such a new list it may take awhile for the guys with more radial experience to find it and chime in.
This link gives a fairly decent overview of the radial - http://en.wikipedia.org/wiki/Radial_engine
Odd number of cylinders for the every other firing order.
On the M14 the cam is a steel disk with two rows of lobes on the outer perimeter, front row is for intake and rear row is for exhaust.  The disk is in front of the cylinders (you can see the push rods on the front of engine) it is geared to the crank and turns opposite direction.  Picture of cylinder assembly here   http://www.goflyamoose.com/Main%20Pages/m14p.html  bottom link on page - M14 cylinder drawing.
Hydraulic lock is an issue but if proper procedures are followed it won't be a "problem".  A lot of the M14's are installing lower cylinder manifold drains or "clean kits" to help reduce the pooling of oil in the bottom 3 (typically) cylinders.
Hope that helps a little.
Scott
Murphy Moose M14P
On 1/30/06, N395V <N395V(at)direcway.com (N395V(at)direcway.com)> wrote:
--> M14PEngines-List message posted by: "N395V" <N395V(at)direcway.com (N395V(at)direcway.com)>
Milt
N395V
F1 Rocket
ScottA
PostPosted: Mon Jan 30, 2006 7:21 pm    Post subject: Re: Radial engines in general Reply with quote
Not sure why it is putting all those ? marks between when I post using gmail.
n395v
PostPosted: Tue Jan 31, 2006 5:29 am    Post subject: Re: Radial engines in general Reply with quote
Massive amount of really great info Smile
Milt
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
