hcourier(at)cox.net Guest
Posted: Tue Nov 28, 2006 7:54 pm Post subject: Commander part needed |
Hello,
I am in need of an idler arm pulley wheel and eccentric for the right engine (the fan belt idler arm eccentric belt tightner) of the Aero Commander 680 FLP I fly. The pulley bearing decided to come apart 10 minutes out of Oxford, MS last Monday. Actually didn't know it until I got on the ground other than that the alternator wasn't quit taking a load. I though it was an alternator or regulator problem.
Once on the ground I found two broken fan belts, and the pulley just as "loose as a goose" on the idler arm. The idler arm pulley wheel part number is: LW 10578. The wheel itself is for a two fan belt setup.
Anyone who may know where I can get one please let me know, I'm based in Destin, FL. My email address is: hcourier(at)cox.net (hcourier(at)cox.net).
I must not know how to use this site as this is the second time I've emailed a request to the site and didn't get a copy myself...which to me means it may not have gotten out to folks. If this is a second "issue" please disregard...unless you have the needed part.
Thank you,
Ray Mansfield
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
