Sony DSC freezing up
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List
DJholl98(at)aol.com
PostPosted: Sun Jan 29, 2006 4:22 pm    Post subject: Sony DSC freezing up Reply with quote
Hi
I have just bought a new laptop to setup my 4000x it doesn't have a serial
port so i bought a usb adaptor. every time i try to start up sony's dsc it
freezes up. 4kcontrol seems to work ok. has any one else had this problem?
should i try a diferent usb adaptor?
also i have a quite loud constant background hiss that seems to be coming
from the 4000k any ideas what could be causing that?
Dave
- The Matronics XDP4000X-List Email Forum -
http://www.matronics.com/Navigator?XDP4000X-List
d.lengacher(at)mchsi.com
PostPosted: Sun Jan 29, 2006 5:56 pm    Post subject: Sony DSC freezing up Reply with quote
debug it i was told by a computer nut after i fixxed my problem (i bought an
old win 98 laptop works great) but i was told in xp you can use debug to fix
the dll's
tbone7467(at)yahoo.com
PostPosted: Sun Jan 29, 2006 6:30 pm    Post subject: Sony DSC freezing up Reply with quote
what about win compatibility mode as that software was made for win 98 an 2000
the dll's
bobbybraun(at)comcast.net
PostPosted: Sun Jan 29, 2006 6:35 pm    Post subject: Sony DSC freezing up Reply with quote
Did you make sure that the comm port you assigned the USB>Serial adapter to is open and free from conflicts? View properties under device manager to view your device and ensure that the comm port it is assigned to is not already being used by any other peripherals on your computer. Also ensure that the comm port chosen matches the one you are selecting with the Sony DSC program. Also, it wouldn't hurt to ensure that you are running under Windows 98 compatibility with the DSC executable. Lastly, close all programs running in the background. Best of luck!
-------------- Original message --------------
the dll's
mdx400(at)hotmail.com
PostPosted: Mon Jan 30, 2006 12:27 pm    Post subject: Sony DSC freezing up Reply with quote
Hi
Dave
Hmm, I had a problem with using a certain program on my computer (which does
have a serial port) and it was easily solved. The program was to control
Sony ES receivers via their RS-232 port but I kept getting some weird
exception error and the program crashing before it even loaded up.
The solution was to get a file, mscomm32.ocx. This file may or may not be
on your system already, you can do a file search to look for it.
Then (this is assuming you put it in the C:\ root directory) open the run
box on XP (Start---->Run; or Windows Key + R) and type in "regsvr32
c:\mscomm32\mscomm32.ocx".
After I did that the program worked fine. This may or may not work for you
however, but it is worth a try I'd say.
Roland M.
IanH
PostPosted: Wed Feb 01, 2006 9:10 pm    Post subject: Re: Sony DSC freezing up Reply with quote
DJholl98(at)aol.com wrote:
Hi
This is my first post, but been lurking for a while Embarassed
I initially had the same problem when I tried to connect my IBM T40 (running XP Pro) to my 4000x using a USB to serial adaptor. I found the problem was that the USB adaptor was showing up as COM5 but the DSC software only looks at COM 1,2,3 & 4.
If you go into the device manager you can force the USB adaptor onto one of the other spare COM ports. As soon as I told it that it was COM2, everything started to work fine.
Ian.
DJholl98(at)aol.com
PostPosted: Thu Feb 02, 2006 6:31 pm    Post subject: Sony DSC freezing up Reply with quote
HI
Thanks for the replies... i tried changing the com number and starting it in
win98 compatibility mode and also bought a different brand of adapter
(belkin) to make sure it wasn't that, and no luck so far. i'll try some other stuff
this weekend.
Dave
PostPosted: Thu Feb 02, 2006 8:36 pm    Post subject: Sony DSC freezing up Reply with quote
May sound like a dumb question, but are you sure you're using a null-modem serial cable?
HI
stuff
this weekend.
Dave
-- XDP4000X-List message posted by: DJholl98(at)aol.com
HI
stuff
this weekend.
Dave
ics.com/xdp4000x-list/subscribe
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List All times are GMT - 8 Hours
