Fuel Pump Placement and Fuel Line Question
lwhitlow
PostPosted: Sun Nov 26, 2006 5:21 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
Hi All
I have decided to go the two fuel pump route in my 601XL. Pumps to be located in the wings
Ive seen the pics on the CH601 site of the pump installed between NR1 and 2
Looks lie a sturdy installation but you would have to rip the entire leading edge off of the wing to do a replacement.
I took some measurements on my right wing this evening and it looks like the pump could be mounted on the side of NR1 directly (possibly with a doubler) in the space between NR1 and the fusalage. If the pump needs service you have to pull the wing, but that seems easier than removing all of the rivets in the top of the LE skin.
It look like about 12 inches of line from the tank to the inlet of the pump, and I would put a filter in that line accessable from the inspection hole in the LE by NR3
Wadaya guys think?
Also if the rubber fuel line in the kit is not the best way to go, What other flexible fuel lines should I be looking for?? (not looking to start another Green SCOCHBRITE merry-go round Laughing
Larry
601XL in Indiana
bryanmmartin
PostPosted: Sun Nov 26, 2006 6:09 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
I wouldn't put a filter on the suction side of the fuel pump. It
isn't necessary and it increases the risk of a fuel stoppage. All you
should have on the suction side of the pump is the screen in the
tank. The screen keeps the bigger stuff out of the fuel pump and
filter will keep the small stuff from clogging the carbureter jets.
The filter should go in the line just before the carburetor. Even on
cars the filter is on the pressure side of the pump.
On Nov 26, 2006, at 8:21 PM, lwhitlow wrote:
Hi All
NR1 and 2
LE skin.
Wadaya guys think?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
dredmoody(at)cox.net
PostPosted: Sun Nov 26, 2006 6:37 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
I made a pair of mounting brackets that are rivetted to NR2 and NR3. The brackets support the 40501 fuel pump in each wing. The bracket and pump are displaced forward of the oval access hatch in the bottom of the leading edge skin. The pumps are secured to the brackets by two AN3 bolts (each) that engage rivetted platenuts. The access hatch allows inspection and maintenance of the finger screens, the barbed hose fittings, clamps, the unjustly maligned Bing fuel line, the pump, its wiring etc. The pump can be removed and replaced as needed through the access hatch without attacking the leading edge skin itself. In other words, I'm not sure why a wing mounted pump would have to be placed anywhere else. This seems like the obvious best place to me. I have photos if you are interested.. contact me off list,
Ed Moody II
Rayne, LA
601XL/Jabiru/baggage area
lwhitlow
PostPosted: Sun Nov 26, 2006 7:07 pm    Post subject: Re: Fuel Pump Placement and Fuel Line Question Reply with quote
HI Ed
Pics would be great!! Maybe I have fat hands but I can't see how I coud get the pump loose and out of the access port. Even if i had a threaded mount for the pump getting a tool in there and holding the pump seems to be tough. Plus the associated fuel lines would take up some space
I would love to see your install and how you solved the problem. Why not post a pic here so we all can see?
Bryan
the Facet install sheet specifies a 70 micon filter on the inlet side of the pump
Has anyone else put a filter on the inlet side of the Facet pump??
p.mulwitz(at)worldnet.att
PostPosted: Sun Nov 26, 2006 7:08 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
Hi Ed,
It sounds like a fine installation for the pumps.
How do you deal with the electrical and fuel line switching? Do you have it so only the active fuel line gets fuel pump electrical power? Do you have one pump pumping against a closed valve at the selector? Do you need to switch one pump on and another one off when you switch tanks?
It seems to me the problems relating to switching the tank and pump at the same time are the worst part of using pumps in each wing. This problem goes away completely if the electric pump is on the engine side of the fuel line selector valve.
Best regards,
Paul
XL fuselage
Ed Moody II
Rayne, LA
- [quote][b]
PostPosted: Sun Nov 26, 2006 7:40 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
There's really no problem as I see it. In most aircraft, the boost pump is switched on, at least briefly, before the demand occurs (ie starting the engine). In mine, the two wing tanks are plumbed to the selector valve; from there on to the gascolator; from there on through the firewall and the inline filter then the carb.
On the pump electrical power issue, I have the EXP BUS which has a single fuel pump switch protected by one of their solid state circuit breaker devices. I intend to go from that switch output to a left/right toggle switch to direct the power to the desired pump. The selector switch will be located in the center console right by the selector valve handle. In a routine situation, before switching tanks flip the boost pump selector switch and flip the power on at the EXP BUS, then switch tanks. In an urgent situation, switch tanks first then flip the selelctor switch and turn on power at the panel.
Remember these are boost pumps that are normally only used during full power at takeoff and climb, or in the pattern on approach. The tank and the pump to which power can be sent have already been selected when things get busy. The only other time would be if I had reason to suspect bubbles in the line (full or partial loss of engine power inflight) so the action in that case is to simply switch power on at the panel (the tank and pump are already selected).
Ed
PostPosted: Sun Nov 26, 2006 7:52 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
I'm a dentist and small work spaces are not scary to me but this one is really no sweat. I did make the access port as big as the space would allow but that is not much bigger than what was called for in the plans. A small ratchet handle, a short extention and a short socket do the job of installation / removal with reasoanble ease. Beats a root canal on an upper second molar anyway.
Ed
Don't bother flaming me on the Bing fuel line... that's what I'm using.
 Filesize:  291.49 KB
 Viewed:  511 Time(s)
PostPosted: Sun Nov 26, 2006 8:11 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
Hi Ed,
I guess my thinking was a little different regarding the electric pumps.
With a low wing airplane, a fuel pump is as necessary to the engine as spark plugs. The real purpose of the electric pump is to provide fuel when the mechanical pump fails. We turn them on at critical moments in anticipation of a potential mechanical pump failure. If the mechanical pump is so nasty as to quit while we are landing or taking off then the electrical pump keeps the engine running.
Your scenario sounds pretty good to me. It is a bit complicated by the two switches rather than just one. I wonder if there will be any damage to either the pump or the fuel lines or other fuel system components like filters if the wrong pump is powered up when it cannot actually cause fuel to flow.
Best regards,
Paul
XL fuselage
At 07:40 PM 11/26/2006, you wrote:
[quote]There's really no problem as I see it. In most aircraft, the boost pump is switched on, at least briefly, before the demand occurs (ie starting the engine). In mine, the two wing tanks are plumbed to the selector valve; from there on to the gascolator; from there on through the firewall and the inline filter then the carb.
Ed
jpollard(at)ciaccess.com
PostPosted: Sun Nov 26, 2006 8:18 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
I am using gates fuel injection hose in the outboard wing sections with fuel
injection type hose clamps. These clamps have the little nut and bolt that
squeezes the springy metal part of the clamp. They stay tight when the
material they are clamping expands and contracts with heat. The hose is the
latest type and is not affected by any of the present gas or diesel
formulations.
This fuel line is called SAE 30R9 and is described in this gates document.
www.gates.com/common/downloads/files/Gates/brochure/TechTipsForm.pdf
or here (same thing)
http://acdelcotechconnect.com/pdf/tsb/tsb_fuel_line.pdf
Jim Pollard
Merlin Ont
craig(at)craigandjean.com
PostPosted: Sun Nov 26, 2006 8:46 pm    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
But it looks like you are using crimped clamps which is good Smile
-- Craig
bryanmmartin
PostPosted: Mon Nov 27, 2006 5:51 am    Post subject: Fuel Pump Placement and Fuel Line Question Reply with quote
A 70 micron filter is just a fine mesh screen like those found in
gascolators and the screens in automotive fuel tanks. The stuff
blocked by these screens winds up in the sediment bowl or fuel tank
sump where it can be drained during pre-flight. My fuel pumps are
just downstream of the gascolator at the low point of the system. I
certainly wouldn't put anything finer ahead of the pump.
The idea is to minimize any flow restrictions on the inlet side of
the pump to avoid reducing the pressure to the point where the fuel
might vaporize in the line.
On Nov 26, 2006, at 10:07 PM, lwhitlow wrote:
Bryan
side of the pump
Bryan Martin
N61BM, CH 601 XL,
Bryan Martin
do not archive.
