TimRhod(at)aol.com Guest
Posted: Sat Nov 25, 2006 2:07 pm Post subject: multiple engine leads from one source |
Does anyone know if you can pull multiple leads off of CHT probes, EGT probes, and Oil Temp to feed two different engine analysis systems. I have a Vision Micro system VM1000 and now a new Grand Rapids EIS. I would Like to use both as back up but would also like not to have to install duplicate CHT, EGT, oil temp Probes. Thanks Tim
nuckollsr(at)cox.net Guest
Posted: Sat Nov 25, 2006 3:52 pm Post subject: multiple engine leads from one source |
At 05:05 PM 11/25/2006 -0500, you wrote:
Quote: | Does anyone know if you can pull multiple leads off of CHT probes, EGT
You can . . . IF.
It's dependent upon the signal conditioning circuitry in
the two instruments. Some systems will tolerate paralleling
as you've suggested but without seeing schematics of the
two systems and/or talking with the designers, it's not
possible to make a recommendation.
stein(at)steinair.com Guest
Posted: Sat Nov 25, 2006 7:08 pm Post subject: multiple engine leads from one source |
Hi Tim,
With some probes yes, and others no. The most likely answer to your question is no. I'm a bit confused to begin with why you have 2 engine monitors (both have quite a good history of reliability) with GRT having literally THOUSANDS of those units flying with little to know problems that I've known about. Splicing CHT's & EGT's could be a slippery slope...there are many different kinds of wire & probes between mfgrs (such as shielded/unshielded, grounded/ungrounded, solid/stranded, etc..). All are setup to read certain specifics. Paralleling onto them could cause lots of problems. Some transducers however allow you to split their signals. It's much easier on powered/excited probes than plain old resistive ones. In basic resistive probes if you "tack on" other things it can significantly vary the readings...
Hope that helps. In the end I'd just say stay away from that and decide which engine monitor to use. Two of them is frankly a bit of overkill in my opinion. If the fan is turning you're most likely ok Duplicate CHT's & EGT's don't buy you much - you can't possibly watch all of each systems indications all the time anyway. If they don't match, now you have to try and decide which one is the "master" or is "right". If you're doing this when you have a problem then you're not flying the plane.
Anyway, enough of my bantering. I get this question asked with surprising regularity and I still can't figure it out! Sorry for being sarcastic, that's not my intent. I'm just trying to point out that with added complexity comes reduced reliability and little gain in form or in function.
Stein.
[quote] --
Posted: Sat Nov 25, 2006 8:06 pm Post subject: multiple engine leads from one source |
Thanks for the input Tim
ainut(at)hiwaay.net Guest
Posted: Sat Nov 25, 2006 8:33 pm Post subject: multiple engine leads from one source |
You know the old saying: never use just 2 watches...
David M.
Stein Bruch wrote:
[quote] Hi Tim,
Stein.
