Service Bulletin SB-912-043 R2
hgmckay
PostPosted: Sat Nov 25, 2006 6:18 am    Post subject: Service Bulletin SB-912-043 R2 Reply with quote
Gentlemen:
<![if !supportEmptyParas]> <![endif]>
If you have a Rotax 912UL and you are using 50/50 water/glycol coolant you need to read this SB and the accompanying explanation. Do any of you know where one can get the “sensor” and “gauge” required by this Bulletin?
Hugh McKay
Allegro 2000
N661WW
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
Sjklerks(at)aol.com
PostPosted: Sat Nov 25, 2006 1:52 pm    Post subject: Service Bulletin SB-912-043 R2 Reply with quote
Hi Hugh, I don't know if John has any thing, but Rans aircraft has a Tee fitting that the water temp probe fits into. I mounted mine between the tank and alum tube. Works great
              Jim
              IV- 912
Thom Riddle
PostPosted: Sun Nov 26, 2006 5:18 am    Post subject: Service Bulletin SB-912-043 R2 Reply with quote
Wicks Aircraft Supply has a TSO'd 2 1/4" Westach water temperature
gauge and sender complete for $100. A good bit less than the UMA
instruments (non-TSO'd) at Aircraft Spruce.
http://www.wicksaircraft.com/catalog/product_cat.php/subid 758/
index.html
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
