Antenna Tester
TSaccio(at)aol.com
PostPosted: Sun Jan 29, 2006 10:43 am    Post subject: Antenna Tester Reply with quote
Does anyone have any information on antenna testers. I've installed copper
foil antenna's in my Seawind and I need to test there integrity. If anyone
could tell me where I could purchase such a unit it would be greatly appreciated.
Tom Saccio _tsaccio(at)aol.com_ (mailto:tsaccio(at)aol.com)
nuckollsr(at)cox.net
PostPosted: Sun Jan 29, 2006 12:46 pm    Post subject: Antenna Tester Reply with quote
appreciated.
There are a variety of low cost, 'swr' meters that need
your vhf comm transmitter as a signal source for operation.
Some don't work very well (show low SWR when in fact the
match is poor). My personal favorite is the MFJ-259. I've
owned two and have purchased them for clients. They've gone
up about $100 since I purchased my first one some years ago
but they're still about the best value out there for serious
antenna work. See:
http://www.mfjenterprises.com/products.php?prodid=MFJ-269
and
http://www.mfjenterprises.com/man/pdf/MFJ-269.pdf
This is the kind of tool a club ought to own and 'rent'
out. I used to rent one but after it had been out and back
about 10x (break even on acquisition cost) it was needing
too much maintenance attention to make it a useful business
activity. I refurbished the rental and sold it. Purchased a
second one which has been used more than enough times to justify
having it.
< with experiment. >
< --Lawrence M. Krauss >
BigD(at)DaveMorris.com
PostPosted: Sun Jan 29, 2006 1:25 pm    Post subject: Antenna Tester Reply with quote
If you scrounge up a used one, make sure it's designed for VHF. There are
a lot of used ham radio units you might find on eBay that only work well on HF.
Dave Morris
N5UP
At 02:41 PM 1/29/2006, you wrote:
<nuckollsr(at)cox.net>
>appreciated.
antenna work. See:
and
having it.
TSaccio(at)aol.com
PostPosted: Sun Jan 29, 2006 1:33 pm    Post subject: Antenna Tester Reply with quote
Thanks for the imput Dave. I don't know anything about this stuff. Are you
saying that a Ham radio that operates on VHF will test the antenna's on my
plane? Tom Saccio _tsaccio(at)aol.com_ (mailto:tsaccio(at)aol.com)
brian
PostPosted: Sun Jan 29, 2006 2:30 pm    Post subject: Antenna Tester Reply with quote
You aren't looking for a ham radio, per se. You are looking for an SWR
meter (or directional wattmeter) that is designed to operate at 120 MHz.
Bob used to have an antenna analyzer he used to loan to people just for
this purpose.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
PostPosted: Sun Jan 29, 2006 3:05 pm    Post subject: Antenna Tester Reply with quote
Brian's right. You just need the SWR meter (aka "SWR Bridge"). Then you
use your own aircraft band transmitter. I bought an SWR meter a long long
time ago from Radio Shack and it's worked dandy for me for all these
years. What I was basically warning you about is that there are some SWR
meters that are not designed for VHF. I used to have a Heathkit SWR meter
that would only work on HF, and not VHF. So be careful if you are going to
go out there and pick one up on eBay.
Dave
you
my
this purpose.
gert.v(at)sbcglobal.net
PostPosted: Sun Jan 29, 2006 3:21 pm    Post subject: Antenna Tester Reply with quote
i bought a simple SWR off ebay, a MFJ-841, which seem to do the trick,
The MFJ-259 is nice, but takes more explaining to the folks using it who
are less techno-literate.
this purpose.
is subject to a download and archival fee in the amount of $500
wschertz(at)ispwest.com
PostPosted: Sun Jan 29, 2006 3:46 pm    Post subject: Antenna Tester Reply with quote
Check with your local Ham Radio club. Someone may have the equipment and do
the test for you.
Bill Schertz
KIS Cruiser # 4045
VE3LVO(at)rac.ca
PostPosted: Sun Jan 29, 2006 8:19 pm    Post subject: Antenna tester Reply with quote
Following the thread:
One of our corespondents is correct - check with local ham club.
Some old duffer witrh an antenna analyzer (SWR don't tell you everything)
will probably come out for the curiosity, test to the nth and offer some
interesting antenna information.
Hams have been swamped in latter years by Japanese black boxes
and the single guy can't compete - antennas are another story. Some of the
best are homebrew and one tenth the cost.
The analyzer is delicate and easily misapplied. Bob won't be
loaning his out for long - the cost to repair within guidelines is
prohibitive.
Thass that.
Cheers, Ferg
PS While this list is amazing for the info in it, there's a lot of
misinformation hidden in some messages. An amateur is a professional who
doesn't get paid - unlike professional pallbearers, etc..................
