acs(at)acspropeller.com.a Guest
Posted: Sat Jan 28, 2006 10:09 pm Post subject: Test Flying |
Just a general request for opinions from everyone.....especially from the flying 10 pilots and the soon to be...
Is there a minimum range of experience you would recommend for undertaking your own solo and testing program in the RV-10?
John
40315
deruiteraircraftservices( Guest
Posted: Sun Jan 29, 2006 2:56 am Post subject: Test Flying |
Hi John,
I'm not giving you an outright answer to your question, but I always view these questions and compare them to myth of Rolls Royce automobile dealers; "if you ask how much they are , you can't afford them".
Maybe a bit more practical; have you flown anything as fast as a -10? Think Saratoga SP, Turbo Centurion, Beech 36?
Have you ever been caught up in unusual attitudes(unintentional)? If the answer to these two questions is no, then it's probably better to find someone who has this type of experience.
Knowing someone's experience is not going to warrant you from having an accident due to lack of experience during your testfase. Your experience would have to be comparable on a like for like basis. Your reactions in situations have to similar and just as fast, if not faster.
If you can get a 'proper' testpilot to do the first couple of hours with you it is money well spent. It doesn't really matter whether they're civilian or military.
coop85(at)bellsouth.net Guest
Posted: Sun Jan 29, 2006 5:26 am Post subject: Test Flying |
John,
I would also agree that it’s largely an “it depends” question. If you have a local EAA chapter I would recommend you talk to a First Flight Advisor. He/She will have video and a checklist of sorts that discusses this pretty well in addition to how to conduct the fist series of flights.
Marcus
dlm46007(at)cox.net Guest
Posted: Sun Jan 29, 2006 5:33 am Post subject: Test Flying |
If you are in the AZ area, I recommend getting the test pilot who does the first flights for Phoenix composites. He flies new Glasair, Glastar, Lanceair 4P, Thunder Mustang etc. And at $100 per hour his service is a bargain.
schmoboy(at)cox.net Guest
Posted: Sun Jan 29, 2006 7:07 am Post subject: Test Flying |
There's a few good links on the RV-10 Wiki...
<http://www.rv10wiki.com/index.php?title=Flight_Test_Info>
-Sean
David McNeill wrote:
[quote] If you are in the AZ area, I recommend getting the test pilot who does
noel(at)blueskyaviation.n Guest
Posted: Sun Jan 29, 2006 8:30 am Post subject: Test Flying |
John,
I have test flown 9 or 10 experimentals now. I would go with the “if you have to ask, you can’t afford it”. Here is real deal: and it all comes down to your comfort level. Most crashes on the first flight are due to pilot error, not keeping up with the aircraft. For insurance you will most likely be asked to get 5 hours instruction and then fly 10 hrs solo. Since you can’t get instruction during phase one that obviously puts you in someone else’s aircraft. After you complete that training, then see if you ask how much for the Rolls.
By the way it is that 15-20 Hr mark that will bite your ass.
Noel
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John
Sent: Saturday, January 28, 2006 11:06 PM
To: rv10-list
Subject: Test Flying
John
40315
