Bill Vincent
Posted: Sat Nov 18, 2006 6:46 pm Post subject: Picture of Homer Kolb |
Hi Gang
For the new List members who have not seen this picture, I thought it was worthy to resend.
The picture is of Homer Kolb with a 1956 design powered by 4 chainsaw engines, I guess this proves once and for all who the "real father" of ultralights really is.....
Bill Vincent Firestar II
Upper Peninsula of Michigan
| Description: |
| Filesize: |
100.45 KB |
| Viewed: |
376 Time(s) |
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
Richard Pike
Posted: Sat Nov 18, 2006 6:57 pm Post subject: Picture of Homer Kolb |
It looks as if he is looking at his left hand. Probably making sure all his fingers are still there.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
dcreech3(at)hotmail.com Guest
Posted: Sun Nov 19, 2006 9:02 am Post subject: Picture of Homer Kolb |
Was it actually N-numbered? Looks like "N2H" on the fin, either a
three-digit N number or a joke . . .
Lee in Ky
Firestar II
| Quote: | From: "Bill Vincent" <emailbill(at)chartermi.net>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Picture of Homer Kolb
Date: Sat, 18 Nov 2006 20:45:43 -0600
Hi Gang
worthy to resend.
| Quote: | << HOMER_KOLB.jpg >>
Share your latest news with your friends with the Windows Live Spaces
friends module.
George Alexander
Posted: Sun Nov 19, 2006 9:32 am Post subject: Picture of Homer Kolb |
I'm betting it may have been N2HK.... Check faa.gov under aircraft n numbers
and there is a de-registered craft with that number and the model name is
"Feather". Most recent registration is a MK II Twinstar.
DO NOT ARCHIVE
George Alexander
FS II FL
http://gtalexander.home.att.net
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
George Alexander
Posted: Sun Nov 19, 2006 9:34 am Post subject: Picture of Homer Kolb |
That most recent registration should have been: TWIN STAR MSK-1 Not MK II
Twinstar.
DO NOT ARCHIVE
FS II R503
E-LSA N709FS
Posted: Sun Nov 19, 2006 11:31 am Post subject: Picture of Homer Kolb |
George A:
Thanks for bringing that to our attention. Here is the info on the
deregistered Kolb Feather:
Deregistered Aircraft 1 of 1
Aircraft Description
Serial Number K2 Type Registration Unknown
Manufacturer Name KOLB Certificate Issue Date None
Model KOLB FEATHER Mode S Code 50307012
Year Manufacturer None Cancel Date / /
Reason for Cancellation Unknown Exported To
Notice the Serial Number: K2. Must have been the second Kolb
aircraft Homer built and flew. Too bad there are no dates on it.
Here's the info on the other Kolb:
Serial Number 3-A Type Registration Corporation
Manufacturer Name KOLB COMPANY INC Certificate Issue Date
01/28/1984
Model TWIN STAR MSK-1 Status Undel Tri
Type Aircraft Fixed Wing Single-Engine Type Engine
Reciprocating
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code 50307012
MFR Year 1983 Fractional Owner NO
This aircraft was built in 1983 and registered in 1984. That is cool.
I love Kolb history.
_________________ John Hauck
Titus, Alabama |
flykolb(at)pa.net Guest
Posted: Mon Nov 20, 2006 4:37 pm Post subject: Picture of Homer Kolb |
Early N numbers for experimentals started out low and the early birds got
the worms. The early guys got the low numbers and these became prestigious
and sought after. As I recall Homer sold one of his early N numbers for
$1,000. This was back when $1,000 was worth something.
That's how I recall it.
Dennis
Posted: Wed Nov 22, 2006 7:46 am Post subject: Picture of Homer Kolb |
And I assume that there was no "ultralight" category as such, so you had to
have an N number to fly legally even with chain-saw power.
It would be interesting to know the specifications of that machine, such as
weight, speed, total horsepower, etc. I wonder if that information still
exists?
Someone should put together a history of Homer and his designs.
Lee
[quote]From: "Dennis Souder" <flykolb(at)pa.net>
Subject: RE: Picture of Homer Kolb
Date: Sun, 20 Jan 2002 01:57:43 -0500
Dennis
Posted: Wed Nov 22, 2006 7:44 pm Post subject: Picture of Homer Kolb |
Lee,
You are correct. I'll ask Homer next time I see him about the speeds, but
as I recall Homer once said it had a lift off speed of something like 55 or
60 mph ... with only a 12 ft span it was HOT! Sitting in that thing doing
60 mph that close to the ground must have seemed more like 100 mph. Must
have been a quite a rush!
I don't think he flew it more than a couple times. Too HOT!
Next version traded one engine for another 5 ft of wing span - that one flew
much better.
When I was a kid, I remember one time going down to the river to watch this
guy fly a glider on floats pulled behind a boat. The boat accelerated and
the glider lifted off and was soon flying. But almost as soon as it gained
just a bit of altitude the wings folded up and down it went. Pilot was wet
and pretty disgusted, but otherwise ok.
Many years later when we were building airplanes, I asked Homer what
happened that his wings folded up so quickly. He replied that he had used
hardware store eye-bolts for attaching the wire-braced wings. The eye-bolts
just opened up when the flying stress was applied. Homer learned many such
lessons the hard way. His next glider had the same hardware store
eye-bolts, but these he had welded so it now had a closed loop.
Dennis
exists?
Lee
Dennis
