echristley(at)nc.rr.com Guest
Posted: Sat Nov 18, 2006 3:58 pm Post subject: lighted toggle switches |
Bob,
I've settled on lighted toggle switches made by Lumex, with a plan to
run all the LEDs through a dimmer circuit composed of one of those MPJA
DC motor controllers. Now that I'm about to put them all together, I'm
not sure how the wiring is supposed to go. A diagram of the switch's
internal circuit can be found at
http://www.lumex.com/spec.asp?p_n=CLS-TC11A12251B The diagram is on
the lower right of the page.
I thought that the switched circuit would be between the POWER and
GROUND terminals, and I would connect my dimmer power line to ACC. I'm
now thinking that the switched circuit will be between POWER and ACC,
and that I will have to modify the motor controller to cycle a
transistor that grounds the GROUND tab to dim the LEDs. Can you
please set me straight?
vhimsl(at)adelphia.net Guest
Posted: Sat Nov 18, 2006 5:44 pm Post subject: lighted toggle switches |
Hello Ernest,
Examining the Lumex schematic, you run +12 VDC to the 'power' input, the ACC
pin to the device you wish to control, with the device going to ground.
You would connect the dimmer to the ground of the LED ground (adding
resistance to dim) and then ground the other side of the dimmer.
I too wish to use lighted LED switches (they make so much sense). However
looking at the switch wiring, it appears that the LED only lights when the
switch is in the 'ON' position. I want the LED lights to be lit when they
are off as well so I can find them in the dark.
Vince
RV8-Finish
