Float Flyr
Posted: Sun Nov 12, 2006 7:45 pm Post subject: Model III-A?? |
To all the Kitfox flyers...
My kitfox is registered as a model III-A. The serial # is 736. I was going
through some of the paper work the other day and noticed the original order
was for a model II.
I am wondering where I can go to find out what has to be done to the plane
to increase the MTOW from 950 to 1050 safely. Transport Canada has agreed
to bump it up if I really want it. I would like to do that only if it is
safe.
The question is this: Is my plane actually a model 2 1/2??? It has the
separate engine mount and the wing tanks with the small header tank under
the panel. The wings are concave on the bottoms. At the time the plane was
originally sold as a kit the Rotax 912 engine was an option.
I've checked with John McBean and he is as much in the dark as I am on this
one..... I guess this one is extra unique.... I don't suppose Dan Denney is
still around??
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Nov 12, 2006 9:49 pm Post subject: Model III-A?? |
Noel,
Do ou have a serial number. We have 17 model IIIs and 13 Model IIs in the
data base. Maybe a serial number and the help from those folks could fix
your airplane in that time frame.
Lowell
henrysfork1(at)msn.com Guest
Posted: Mon Nov 13, 2006 5:31 am Post subject: Model III-A?? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I have a model II the serial number is 345. There were several engine options offered for the model II. The Rotax 582, Rotax 912 and the KFM 112. There were also options available at the time which included two wing tanks and aluminum header tank to be located behind the seat. If you look in the archives you may find the documentation which serial numbers went with which model numbers. Hope this will help some.
Dee Young
Model II N345DY
KFM 112
Posted: Mon Nov 13, 2006 5:45 am Post subject: Model III-A?? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Noel says; To all the Kitfox flyers...
was for a model II.
Noel, If you hit a dead end let me know and I may have the information you need at the hanger.
Dee Young
Model II
Float Flyr
Posted: Mon Nov 13, 2006 6:17 am Post subject: Model III-A?? |
Lowell:
The serial # is 736
I just checked the letter of conformity for the plane.... The first page says model 2 the other pages say model 3... Go figure. The date was '92 I guess that's why TC removed my AULA status.
Noel
Kitfox III-A
Float Flyr
Posted: Mon Nov 13, 2006 6:33 am Post subject: Model III-A?? |
Dee:
What is the MTOW for your plane?
Noel [quote]
Kitfox III-A
Malcolmbru(at)aol.com Guest
Posted: Mon Nov 13, 2006 6:50 am Post subject: Model III-A?? |
MY model 2 is ser 347 the kit was started ain 98 and finished in 2000 I also wonder what mods may make it a 1050 GW I will wach this one mal michigan
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Mon Nov 13, 2006 7:00 am Post subject: Model III-A?? |
Could it be that Denney Aircraft was in a “development” stage of the 3, and you got an interim model between the 2 and 3? Maybe they just started marketing the 3, but still had the model 2 paperwork and designation?
I guess in which case you could call it one or the other.
Does the vertical stab size give any clue?
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Monday, November 13, 2006 9:17 AM
Subject: RE: Model III-A??
Lowell:
The serial # is [b]736[/b]
Noel
| Quote: | | www.aeroelectric.com | 0123456789012345
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
Posted: Mon Nov 13, 2006 7:08 am Post subject: Model III-A?? |
wing strength up dates would increase the GW. not gas tanks or interior options larger rutter would help w/ cross wind capabilities
Float Flyr
Float Flyr
Posted: Mon Nov 13, 2006 8:17 am Post subject: Model III-A?? |
I quite agree. I only put in the equipment that is in my plane to give others a bit of an idea as to what my plane has installed. I was hoping they might be able to tell me what to look for in a plane that has the 1050 lb. MTOW. If my plane confirms to what is expected then I will proceed with getting the registration changed. TC says I can do that but I'll only do it if it's safe to do so.. Not that they would let me do it if it was not safe.
Noel [quote]
Kitfox III-A
Posted: Mon Nov 13, 2006 11:20 am Post subject: Model III-A?? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> In the POH for the Model II the gross is listed at 950 lbs. and the MTOW is listed at 1050 lbs.
Dee
Posted: Mon Nov 13, 2006 11:30 am Post subject: Model III-A?? |
Noel,
I understand that on the IV, it can be changed from the 1050 grwt to the
1200 grwt by drilling the lower strut attach brackets and inserting a 4130
rod threaded at both ends through the carry through tube with washers and
nuts securing it in place. That strengthens the carry through. The rest of
the mod is the thicker wall lift struts. This from Frank Miller. Don't
know if the present factory would authorize these mods.
Lowell
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Model 2 serial numbers ranged from #258 to #748. This might help some too.
Dee
GENTRYLL(at)AOL.COM Guest
Posted: Mon Nov 13, 2006 12:59 pm Post subject: Model III-A?? |
The third item is the spar reinforcement inserts.
Float Flyr
Float Flyr
Posted: Mon Nov 13, 2006 1:24 pm Post subject: Model III-A?? |
Dee: I hate to look so stunned but...
I thought gross weight and MTOW were the same thing. I guess I've missed something here. How does the POH differentiate between the MTOW and Gross weight? The extra hundred pounds will allow me to carry a real passenger. (half tanks)
Noel [quote]
Kitfox III-A
Lynn Matteson
Posted: Mon Nov 13, 2006 3:57 pm Post subject: Model III-A?? |
Ask Steve? : )
Lynn
On Monday, November 13, 2006, at 04:23 PM, Noel Loveys wrote:
[quote] Dee: I hate to look so stunned but...
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
