jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Tue Nov 07, 2006 5:02 pm Post subject: re- RV6a maximum gross weight @1650 lb. |
A month or two ago I registered my RV6-a with the MOT. The application
included the requested gross weight which I set at 1775 lb.
A week later I received the as applied for registration which now resides in
the aircraft as required.
My local inspector is an acquaintance. He was professional diligent and
helpful in all regards. He is in fact a highly trained aircraft structural
AME. By trade.
Yesterday upon having completed the final inspection process of my RV6-a he
had to inform me of the following; It has been decided that the maximum
gross weight during the 25 hr. flight test period will be set by the MDRA at
the kit manufacturers stated (in my case1650 lb.) regardless of the
applicant's requested weight.
It is as yet unclear to me and the inspector exactly how this will effect my
intention to maintain the previously applied for and accepted 1775 maximum
gross weight.
Is this little more than a mild shifting of weight by the MDRA with little
or no effect on the builders?
Will I have to re-test the aircraft for some as yet undetermined additional
flight period?.
It might mean that I have to re-do the gross weight climb test at the
requested 1775 lb. weight.
Will the onus be on me to go through a structural testing regime to prove
the airframe is up to the task.
The first three options can be complied with, the later would of course be
out of the question.
I have no word from the MDRA administration or the local provincial rep. as
to the why's and how's this rule change was arrived at. No advance warning.
No background or explanations offered to the local inspector. No word as to
where this will leave me in dealing with the MOT ? I was informed that after
the 25 hr. test period I will be on my own with the MOT. in this regard.
No opportunity at all to have input on the matter!
My bet is that after turning over one or two rocks in this pile,, a lawyer
will be found !?
Jim in Kelowna
P.S. I almost put the sealed envelope containing the paper work re- the
inpection into the mailbox without checking the amount of postage that was
on it.
Upon doing so I went to the post office and had the postage increased to the
required $1.xx additional amount.
Had I not done so the affixed return address was to the head office in
Ontario instead of here in Kelowna. With the incorrect postage it would have
been returned or sent to Ontario then back to B.C. to be scrutinized By
Terry Elgood before arriving back here. Who knows how long that would take?.
This might explain some of the gripes I have heard about the paperwork turn
around time? If by chance you are given the wrong envelope, a small error
will have a fairly big effect.
| | - The Matronics RVCanada-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVCanada-List |
_________________ "I never make mistreaks" |
George McNutt
Posted: Tue Nov 07, 2006 8:05 pm Post subject: re- RV6a maximum gross weight @1650 lb. |
Hi Jim
Looks like "passing the buck" from MDRA to Transport. You will probably
have to jump through a bunch of hoops for T/C.
You will have to get into T/C's policy letters to get the real hoops
that will be required.
Here is some reading to start with.
http://www.tc.gc.ca/CivilAviation/maintenance/AARPE/Recreational/AMAs.htm
http://www.tc.gc.ca/civilaviation/maintenance/aarpc/msi/Msi_59.htm
http://www.tc.gc.ca/civilaviation/maintenance/AARPC/MSI/Msi_14.htm
Good luck
George in Langley
Jim Jewell wrote:
resides in the aircraft as required.
and helpful in all regards. He is in fact a highly trained aircraft
structural AME. By trade.
RV6-a he had to inform me of the following; It has been decided that
the maximum gross weight during the 25 hr. flight test period will be
set by the MDRA at the kit manufacturers stated (in my case1650 lb.)
regardless of the applicant's requested weight.
effect my intention to maintain the previously applied for and
accepted 1775 maximum gross weight.
little or no effect on the builders?
additional flight period?.
prove the airframe is up to the task.
course be out of the question.
rep. as to the why's and how's this rule change was arrived at. No
advance warning. No background or explanations offered to the local
inspector. No word as to where this will leave me in dealing with the
MOT ? I was informed that after the 25 hr. test period I will be on my
lawyer will be found !?
Jim in Kelowna
the inpection into the mailbox without checking the amount of postage
that was on it.
to the required $1.xx additional amount.
in Ontario instead of here in Kelowna. With the incorrect postage it
would have been returned or sent to Ontario then back to B.C. to be
scrutinized By Terry Elgood before arriving back here. Who knows how
long that would take?. This might explain some of the gripes I have
heard about the paperwork turn around time? If by chance you are given
the wrong envelope, a small error will have a fairly big effect.
f1rocket(at)telus.net Guest
Posted: Thu Nov 09, 2006 1:04 am Post subject: re- RV6a maximum gross weight @1650 lb. |
Jim,
I have a Stits Playboy that I bought and the empty weight was wrong (an
outright lie in my opinion). So I thought I would apply for an increase in GW
from 1500 to 1800 lbs. I filled out all the paperwork as I did for my Rocket
(flap area, wing loading etc) and thought I was set.
MOT has come back and told me that if I wish to have a GW higher than original
design, I need to run all the stress analysis my self and prove it to them. OK
wing was easy, but fuse is beyond my current means, without hiring a
professional or getting a program.
I also can't contact the original designer to get a statement from him (they
would also accept this), so I'm not sure what to do, other than fly under 1500
lbs.
I would think that you could get a statement from Vans that you can have the
higher GW. I wonder what would happen though if Vans refuses? Guess you would
be back to calculating.
With my Rocket I found that as soon as my paperwork was done with MDRA (final
inspection) I was on my own with TC. I can tell you that I had more problems
with the TC paperwork than anything. Basically I didn't mail anything as they
claimed to have lost my file. So I spent a total of three days going back and
forth to get my paperwork in order. Oh and one thing to watch - after your 25
hours are done, make sure they don't just give you day VFR. They tried that
with me and I made them go back and re-type it up to read day/night VFR.
Don't know if I helped or confused?
Jeff
Quoting Jim Jewell <jjewell(at)telus.net>:
AME. By trade.
gross weight.
flight period?.
will be found !?
Jim in Kelowna
on it.
