experimental208nd(at)comc Guest
Posted: Tue Nov 07, 2006 8:03 pm Post subject: Rough Running 912 UL |
Hi List,
I have a 912 UL with 145 tthours. It had a rough spot at about 3000-3200 rpms on the ground or in the air.
I have checked and regapped the plugs to .028,
cleaned out the bowls on the carbs,
cleaned off the neddle and dome area, sanded the ground wire lugs for the coils to get a good ground.
Checked the carb Ballance -its ok.
It all has not helped at all, even makes the rough ness worse some times. Going from 2k rpms- 3k rpms it is almost like it is bogging down, and you have to sort of pump the throttle to get the rpms past the 3-3.2 k mark.
Doing the mag check it is very rough on each side also, and I am using gas with the 10 % methanol( exact amount unknown )
My qquestion is any ideas on the cause, there was no visible dirt or matter in the bowls either?????
I am going to try and put in new plugs and then try some AV gas instead.
Let me know what you think
Jay
propellerdesign(at)tele2. Guest
Posted: Tue Nov 07, 2006 11:58 pm Post subject: Rough Running 912 UL |
To me it sounds (without hearing the engine) that it get to little fuel at that rpm range, can also be to rich.
Idle adjustment?
carb diaphragm?
Leaking inlet tubes?
dirt in the middle range system?
Jan Carlsson
jcpropellerdesign.com
dcsfoto
Posted: Wed Nov 08, 2006 5:59 am Post subject: Re: Rough Running 912 UL |
my 912 runs good but in if I try to run in the 3000-3200 range it seems to run rough or vibrate more. I just avoid that rpm spot
Posted: Wed Nov 08, 2006 7:24 am Post subject: Rough Running 912 UL |
Sounds lean and not safe to fly. Make sure you get
that fixed first. You may be a bit lean overall and
that range is just the worst of the bunch. How are
your EGTīs?
Kurt S. S-5
--- Jay Fabian <experimental208nd(at)comcast.net> wrote:
| Quote: | Hi List,
air.
the 3-3.2 k mark.
Jay
Want to start your own business?
http://smallbusiness.yahoo.com/r-index
lcfitt(at)sbcglobal.net Guest
Posted: Wed Nov 08, 2006 12:24 pm Post subject: Rough Running 912 UL |
Kurt,
This might be right on the money. One of the local 912 guys got rid of his
rough spot by raising the needle one notch. I followed suit.
Lowell
torgemor(at)online.no Guest
Posted: Wed Nov 08, 2006 12:55 pm Post subject: Rough Running 912 UL |
Hi there Jay,
Good description of your rough running engine.
Just change all spark plugs as you suggested, I don't think that you'll
need to change the fuel, -but it is a good idea.
Methanol/ethanol blended fuel is known to cause starting problems during
cold season.
The ignition system Ducati is of the type "wasted spark" system, I.E.
firing twice as often as necessary. However, this is Rotax/Ducati
philosophy, and work great..
The importance here is that one coil winding is firing two sparkplugs
(installed in two different cylinders) at same time, one active and the
other passive (would not ignite anything as this piston is in bottom).
Over time "one" of the plug "might" become some contaminated (sooty and
carbonized).
Those two spark plugs can be compared with two resistors. Since one of the
plugs occasionally can be partly shorted, -most of the spark energy dimish
and most of the spark energy is transferred to the healthy spark plug.
Occasionally one plug might short and this can vary and play havoc with
you.
So, the moral is look at the plug electrode and see if there's one with
darker color, and if you change this plug you must change the "twin" plug
going to the other cylinder. I.E. the "twin plug" is the one connected to
the same coil as the "sooty" one.
But as a rule, we normally change all igniters at the same interval.
P.S. In the ol. days, we leaned the engine on ground for some time -then
the mag check become ok. and the fun could start.
Good luck.
Torgeir.
On Wed, 08 Nov 2006 05:02:50 +0100, Jay Fabian
| Quote: | Hi List,
k mark.
Jay
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Posted: Wed Nov 08, 2006 5:01 pm Post subject: Rough Running 912 UL |
Thanks Lowell,
As you know, I donīt have a 912, but lean is lean on
any 4 cycle and I know about sagging power on others.
My old 2 cycle would run pretty happily rich or lean,
until you fouled a plug or burn a cylinder, but donīt
mess with the timing. That was touchy.
Kurt S.
--- Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
| Quote: | Kurt,
followed suit.
Lowell
Sponsored Link
$200,000 mortgage for $660/mo - 30/15 yr fixed, reduce debt, home equity -
Click now for info http://yahoo.ratemarketplace.com
Posted: Wed Nov 08, 2006 6:29 pm Post subject: Rough Running 912 UL |
Ok, So far I cleaned out the top diafram area with carb cleaner, and the needle had a slight dark ring of residue on it on both pins.
Diaphrams are fine, and back in place
Inlet tubes look fine,
Carb sockets have about 20 hours on them, and are clamped correctly,
One thing I noticed when taking off the top cover of the carbs there is a dark silver / oil looking residue on the two parts that hold the big spring in place. I did not know if it is oil for the spring or just the aluminum rubbing off from the spring. I left it as is for now. Test ran it and the same issues are happenning.
I ran out of light so I will try the plugs, and the teflon seat and valves for wear as per the maitenance book.
I know of people that change the jets 2 X per year depending on temps, but since I built it I have not had to change them at all. The egts have been great and only fluctuate very little all year round 90deg- 20 deg F.
Where is the middle range system located? Is that up behind the float valves?
I hope to get over there Thursday sometime.
Jay
Posted: Wed Nov 08, 2006 11:33 pm Post subject: Rough Running 912 UL |
If it have that system (I am not sure) there is one or more extra holes close to the closed throttle valve, clean this and or the idle jet, and or adjust the idle mixture, because the idle system is working about one third up in the register.
Se http://www.ultralightnews.ca/rotax912/912-914bingCarb.htm
Jan
Off-idle circuit
As the throttle is opened up slightly from the fully closed position, the throttle plate uncovers additional fuel delivery holes behind the throttle plate where there is a low pressure area created by the throttle plate blocking air flow; these allow more fuel to flow as well as compensating for the reduced vacuum that occurs when the throttle is opened, thus smoothing the transition to metering fuel flow through the regular open throttle circuit.
nandrand(at)xtra.co.nz Guest
Posted: Thu Nov 09, 2006 12:23 am Post subject: Rough Running 912 UL |
It may be a silly question, but have you balanced the carbs' ??? Noel
Posted: Thu Nov 09, 2006 1:12 pm Post subject: Rough Running 912 UL |
Yes, They are right on the money, with the duel gauges.
thanks
Jay
ppeerenbo(at)charter.net Guest
Posted: Fri Nov 10, 2006 4:02 pm Post subject: Rough Running 912 UL |
Jay I did this to my self by putting a longer tube on the carb vents. What do your vent tubes look like?
Paul N102DG
