Slick mag P-lead ground wire
duawil
PostPosted: Mon Nov 06, 2006 10:46 am    Post subject: Slick mag P-lead ground wire Reply with quote
I see the P-lead and the ground lug on the back of the Slik mag.
I know I need to use a coaxial wire with the center conductor on the
P-lead and the braided outer conductor on the ground lug.
Two questions:
1) What gage wire do I use. I have some 22 gage coax already run, but is
ths big enough.
2) Do I ground the center conducto to a local ground point at the switch
on the panel or do I ground it to the coax outer conductor?
Duane Wilson
RV9A
Building RV10.
nuckollsr(at)cox.net
PostPosted: Mon Nov 06, 2006 8:30 pm    Post subject: Slick mag P-lead ground wire Reply with quote
Two questions:
ths big enough.
22 is electrically fine . . . at many TC aircraft facilities,
20 or 18AWG is used simply for mechanical robustness.
Grounding to shield is preferred. See exemplar schematics
in:
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
< with experiment. >
< --Lawrence M. Krauss >
lehmans(at)sympatico.ca
PostPosted: Thu Nov 09, 2006 6:12 am    Post subject: Slick mag P-lead ground wire Reply with quote
Bob,
I have found a certified aircraft with the P-lead shield grounded at the mag
switch end as well as on the mag housing. Is there a down-side (i.e. noise)
to grounding the shield at both ends? (Surprisingly, the Maintenance Manual
for the aircraft does not include wiring for the mag switch or P-lead.)
Mike
2) Do I ground the center conductor to a local ground point at the switch
in:
PostPosted: Thu Nov 09, 2006 6:42 am    Post subject: Slick mag P-lead ground wire Reply with quote
At 09:12 AM 11/9/2006 -0500, you wrote:
Bob,
There's a number of discussions for p-lead treatment in
http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf
and
http://www.aeroelectric.com/FAQ/AeroElectric-List/AeroElectric-List_FAQ.pdf
Open the .pdf files and search on "p-lead".
In a nutshell, for best noise reduction -AND- avoidance of
a fabricated ground loop, it's best to ground the shield at
one end only (mag end) and use the shield as the ground return
for the mag switch as illustrated in the z-figures and cited
in the two links above.
duawil
PostPosted: Thu Nov 09, 2006 10:55 am    Post subject: Slick mag P-lead ground wire Reply with quote
Thanks Bob.
I will ground to the shield this weekend!!!
Duane
<nuckollsr(at)cox.net>
> <lehmans(at)sympatico.ca>
>Bob,
> mag
> noise)
> Manual
and
Building RV10.
