wgill10(at)comcast.net Guest
Posted: Sun Nov 05, 2006 7:44 am Post subject: Airflow Performance fuel servo set-up (RV-7 w/IO-390) |
Hello All,
If anyone has any pictures of the throttle and mixture cable connections to the fuel servo, please send them my way. I am also trying to find a source for the cable end B-nuts that will fit through the linkage arms on the fuel servo or similar hardware for this purpose (Aircraft Spruce doesn’t have). I have rotated the fuel servo 90 degrees that allows both the mixture and throttle arm linkages to be positioned slightly lower than the sump. Thanks in advance for your assistance.
Best regards,
Bill Gill
Lee’s Summit, MO
dan(at)rvproject.com Guest
Posted: Sun Nov 05, 2006 9:37 am Post subject: Airflow Performance fuel servo set-up (RV-7 w/IO-390) |
Doubt it would be any different than my IO-360-A* installation. http://www.rvproject.com/construction_log.html
Granted the front-mounted gov'r and baffles are slightly different, but the AFP servo + horizontal sump should be identical.
)_( Dan
RV-7 N714D (1127 hours)
www.rvproject.com / www.weathermeister.com
Dick Sipp
Posted: Mon Nov 06, 2006 5:57 pm Post subject: Airflow Performance fuel servo set-up (RV-7 w/IO-390) |
Bill:
The Airflow installation manual has several pictures of various installations. If that is not available, give them a call or an email, there are more pictures available from them. The servo controls would normally be connected with threaded rod end bearings.
Incidentally, I just returned from attending the Airflow Perfomance two-day "Fuel Injection 101" I think it is an excellant value and was well worth the trip.
Dick Sipp
RV10 40065
