Problem with canopy safety latch installation
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
dturren(at)sonic.net
PostPosted: Sat Nov 04, 2006 9:52 am    Post subject: Problem with canopy safety latch installation Reply with quote
Hello everyone: I am installing the canopy safety latch. When I put the SL-1 (safety latch arm) in place (so that the C-615 spring is parallel to the fuselage side rail and the main canopy latch pushes against the tab on the latch arm), I find that the safety latch arm is about 3/8 inch longer than it should be to properly ride under the striker plate as per the instructions. I could find another piece of steel and make a shorter latch, or put a spacer between the fuselage side rail and striker plate. Has anyone encountered the same problem? What did you do?
Thanks in advance… Donna Turrentine
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
