GENTRYLL(at)aol.com Guest
Posted: Mon Oct 30, 2006 8:45 am Post subject: NSI Redrive Oil Seal Leaks |
I recently read where someone in this forum vented his NSI Redrive because it was building pressure due to heat expansion of the oil. I have a new A-40 that is doing the same thing when the transmission oil gets to about 150 degrees. How did you vent it so that you didn't have a leak?
wingsdown(at)comcast.net Guest
Posted: Mon Oct 30, 2006 9:26 am Post subject: NSI Redrive Oil Seal Leaks |
Where is it leaking? Venting should not be required. It should not be leaking. I was told by Lance that oil mist is created and helps lubricate and venting diminishes that to some extent.
Rick
MHastedt
Joined: 27 Aug 2006 Posts: 14 Location: College Station, TX
Posted: Mon Oct 30, 2006 10:59 am Post subject: NSI Redrive Oil Seal Leaks |
I have a Hirth redrive on my (mostly) NSI engine and it definitely has a vent. Originally the vent was on the middle-front face of the unit, just below the prop flange. However, I had to move it to the top fill port position because evidently there's a low pressure zone at the original location when the prop is spinning. It actually vacuumed out most of the redrive oil on one of the first test hops! No problems/leaks with the vent in the top position. (I use gear oil in my redrive - does NSI?)
-Margaret H.
| Quote: | >> wingsdown(at)comcast.net 10/30/2006 11:25 AM >>>
Rick
Posted: Mon Oct 30, 2006 11:28 am Post subject: NSI Redrive Oil Seal Leaks |
How is the vent made? Is it a ported plug, a tapped plug, or what?
Fox5flyer Guest
Posted: Mon Oct 30, 2006 1:10 pm Post subject: NSI Redrive Oil Seal Leaks |
That was probably either me or Peter Graitchen. We both vented ours, but in different ways and with positive results. It eliminated the internal pressure that was causing the oil seepage. I vented mine over 200 hours ago and it's been fine ever since. You can see how I did it by going to our Sportflight.com archives uploads and checking in the NSI category. or you can just click on
http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1058656397
Let me know if you have any questions.
Deke Morisse
S5/NSI/CAP
Posted: Mon Oct 30, 2006 2:06 pm Post subject: NSI Redrive Oil Seal Leaks |
Thanks, that looks simple enough. I'll be trying it shortly.
n10pg(at)neo.rr.com Guest
Posted: Mon Oct 30, 2006 2:21 pm Post subject: NSI Redrive Oil Seal Leaks |
Thats a lot of BS. All NSI redrives, or for that matter, all gearboxes need to be vented. With heat buildup there is a corresponding pressure buildup. With a proper overflow container, you would be surprised how much oil is pushed out and then sucked back in as the gearbox cools.
Peter Graichen
[url=http:/home.neo.rr.com/n10pg/kitfox.htm]http:/home.neo.rr.com/n10pg/kitfox.htm[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of wingsdown
Sent: Monday, 30 October, 2006 12:25
Subject: RE: NSI Redrive Oil Seal Leaks
Rick
Posted: Mon Oct 30, 2006 3:00 pm Post subject: NSI Redrive Oil Seal Leaks |
Nice response. So where is the vent and recovery system on standard transmission in vehicles. I will admit you did a very nice job on the vent. I had 600 hours without a problem.
Rick
Lynn Matteson
Posted: Mon Oct 30, 2006 4:02 pm Post subject: NSI Redrive Oil Seal Leaks |
Sometimes the vent is located right on the top of the standard
transmission casting, and sometimes the pressure goes through the front
bearing, and is released through a shielded hole in the front bearing
retainer (which also serves as the sleeve upon which slides the clutch
release bearing, also known as the throw-out bearing.) If located on
top of the casting, it is usually covered with a squeeze-on metal cap,
to keep water and road gunk out.
Lynn
On Monday, October 30, 2006, at 06:00 PM, wingsdown wrote:
[quote] Nice response. So where is the vent and recovery system on standard
Rick
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 30, 2006 4:45 pm Post subject: NSI Redrive Oil Seal Leaks |
I guess I shouldn't be responding here as I don't own a Sub of any variety,
but there has been occasional talk of oil seals being pushed out by internal
pressures. There was talk of an oil seal retainer and talk of venting. Has
this from memory been a gear box issue?
Lowell
Posted: Mon Oct 30, 2006 4:56 pm Post subject: NSI Redrive Oil Seal Leaks |
Lowell,
I never experienced that problem, but I believe that was the front main
engine seal. There were a few with undersize seals and some with just
too much crankcase pressure.
Rick
dave
Posted: Mon Oct 30, 2006 5:20 pm Post subject: NSI Redrive Oil Seal Leaks |
Most Cars and trucks have vents on the tranny --auto or standard as well as transaxles and front and rear axles.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Mon Oct 30, 2006 5:47 pm Post subject: NSI Redrive Oil Seal Leaks |
It is leaking around the front propshaft seal, but only after flying an hour or so and the temp gets up to around 150 degrees.
smokey_bear_40220(at)yaho Guest
Posted: Mon Oct 30, 2006 7:32 pm Post subject: NSI Redrive Oil Seal Leaks |
I agree with Rick Lowell,
It was the engine front crank seal, not the GB. Mine
drops maybe 10 drips of oil for a long flying day, but
nothing I would worry about. Canīt even find the
source for sure, but it is somewhere at the planeīs
back of the engine (auto front). I canīt find a wet
spot, just some oil below.
Peter G is the source for the GB vent, I believe??? I
remember it as a threaded AL extension from the fill
hole with a small plastic fuel filter on top to vent
thru. Very nice. Wasnīt he the one who made the dip
stick for the GB too????
I am not home again to check my memory on this, so
sorry if I got it wrong.
Kurt S.
--- wingsdown <wingsdown(at)comcast.net> wrote:
| Quote: | Lowell,
was the front main
and some with just
Rick
Get your email and see which of your friends are online - Right on the New Yahoo.com
(http://www.yahoo.com/preview)
