Electroluminescent hum
N941WR
PostPosted: Thu Oct 26, 2006 4:19 am    Post subject: Electroluminescent hum Reply with quote
I have installed an electroluminescent strip to light the switch panel in my RV-9 and this has introduced a low volume hum in the intercom.
Do any of you have a suggestion on how to eliminate this?
My set up is as follows: (And what I have tried)
- All grounds go to a common ground bus, mounted on the inside of the firewall, which is bolted through the firewall to the engine ground bus and negative battery cable.
- The positive lead from the EL power supply is wired in to an Aero Bob dimmer.
- I have removed power to the power supply and the hum goes away.
- I have moved the wires to the power supply
- I have wrapped the power supply in tinfoil
- I have temporarily installed a noise suppressor in the avionics bus feed line.
Bill
cjensen(at)dts9000.com
PostPosted: Thu Oct 26, 2006 5:05 am    Post subject: Electroluminescent hum Reply with quote
Bill,
I had a similar problem and applied two fixes. First, all wires were
returned to the same ground...not looping or daisy-chaining. Second,
the wires to/from the strip were aggressively twisted. I'm unsure which
was the final solution as both were applied when the problem was fixed.
It's a couple things to try.
Chuck Jensen
N941WR
PostPosted: Thu Oct 26, 2006 12:52 pm    Post subject: Re: Electroluminescent hum Reply with quote
Chuck,
Thanks for the input. Unfortunately, I had already done both of those things.
I might try re-routing the wires between the power converter and the strips. (I'm running duel strips since I have a center mounted throttle quadrant in my -9.)
Bill
PostPosted: Thu Oct 26, 2006 1:21 pm    Post subject: Electroluminescent hum Reply with quote
I was running dual strips as well as a number of instrument lights. The
first installation groups the grounds together from a few of the items,
then ran one long lead over to the ground on the converter. Running all
of the grounds back to the converter...as well as doing a Mr. Twister on
them, was the fix. Nonetheless, fiddling with them can sometimes affect
a cure, just like fiddling with them will sometimes initiate the
problem. There is a lot of black magic involved in this stuff (at least
for us uneducated electrical types!).
Chuck Jensen
