occom
Posted: Wed Oct 25, 2006 2:05 am Post subject: Warp prop bolts |
All the talk about the warp prop has me wanting to have a look at mine
mounted. I'm missing a bit of documentation and I'm wondering what bolts are
used on these. I think they are 8mm but am unsure of the length, head etc.
Recommendations?
dave
Posted: Wed Oct 25, 2006 2:18 am Post subject: Warp prop bolts |
Dave,
I think off the top of my head they are AN4 1/4 " for the 12 that hold the
blades in place with Nuts and Washer under nut and head of bolt
and the 6 that bolt to hub are AN 8mm that thread into hub and i use a
8mm an locknut on backside and washer only under head of 8mm bolt
No safety wire at all.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Oct 25, 2006 6:12 am Post subject: Warp prop bolts |
Dave, When I mounted my prop, it seemed that the mounting bolts were a bit
sloppy in the mounting holes - prop and hub. they were 5/16 bolts. I
delayed long enough to order the 8mm bolts and found them to be a looser fit
than the 5/16 ones supplied by Skystar at the time, so went with the 5/16.
The Warp Drive manual calls for either.
Lowell
Float Flyr
Posted: Wed Oct 25, 2006 9:18 am Post subject: Warp prop bolts |
I'm getting the idea I must be old fashioned.... I like to see a nice clean
lock wire job!
Ivo requires lock wire not be used on their props.
Boo hiss! But I do as I'm told.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Wed Oct 25, 2006 4:22 pm Post subject: Warp prop bolts |
Safety wire not an issue on prop bolts with selflocking nuts on back side
like Warp , GSC and Ivos that I have used and set up .
dave
Posted: Wed Oct 25, 2006 4:32 pm Post subject: Warp prop bolts |
Lowell, Thanks -- I have a set of drive lugs to put in my 582 this week
when I try the GSC prop. I always thought there were 8mm but maybe a 5/16s
does work.....
Will try and report back.
Dave
Float Flyr
Posted: Thu Oct 26, 2006 5:01 am Post subject: Warp prop bolts |
I've seen self locking nuts, fibre and metal work loose. Admittedly they
were obviously re used nuts and probably should have been condemned.
Nothing looks as nice as a well done lock wire.
Little holds a well as a cotter pin. Doesn't look as nice though.
Noel
[quote] --
Kitfox III-A
