garyvanremortel(at)gmail. Guest
Posted: Mon May 12, 2025 3:32 pm Post subject: RV-List: Re: VM1000 AMP/Current circuit |
Pretty pricey stuff.
On Mon, May 12, 2025 at 4:29 PM <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
| Quote: | Good job Gary!
I parted out my VM1000 years ago and replaced it with an AFS 3400 when i had issues with mine.
Sent using myEarthLink
On Mon May 12 18:51:47 EDT 2025 Gary VanRemortel wrote:
Not sure if many of you are still flying with the original Lance Turk designed VM1000, but my ammeter circuit was periodically dropping out and I was unable to get advice on the old girl.
I made myself a breakout cable to monitor the signals/voltages on the sensor lines during flight. The 10VDC was dropping out, so I took the DPU apart and traced the supply path to VR2 on the analog PCB. I reasoned that since this 10VDC only powered the ammeter circuit, it must be flakey. I replaced it (TI 78L10AC) and now all is well.
-GV
