Parker Brake Torque Plate
garyvanremortel(at)gmail.
PostPosted: Wed Feb 19, 2025 5:12 pm    Post subject: Parker Brake Torque Plate Reply with quote
I can't believe I haven't seen others having a problem similar to mine.  Parker-Cleveland part 075-00800 Torque Plate is cold rolled steel that deforms over a period of time because it is not hardened or is just too weak for the application. I replaced a badly bent one some years back and  they are getting pricey new $600, and used $200.  I straightened mine this time and had doublers TIG welded on to triple their rigidity in the weak region. Original left, modified right.
 Filesize:  2.05 MB
 Viewed:  10888 Time(s)
 Filesize:  2.07 MB
