Europa as a tow plane?
alan.twigg775(at)gmail.co
PostPosted: Mon Feb 17, 2025 9:16 am    Post subject: Europa as a tow plane? Reply with quote
Not in the UK Wlad, I though of it but I had access to a Pawnee and an Ikarus.(C42)An Ottfur release might be the answer but a strengthening would probably be needed along the inside or outside of the fuselage. The extra weight might not be worth it.
Regards Alan Twigg
Long Wing G-GIWT
On 17 Feb 2025, at 16:27, Wladimir Kummer <wladimirkummer(at)gmail.com> wrote:
Hi,
Been building a Europa XS Long wing variant (s/n A193). Since I´m also a glider pilot I had the crazy idea on adapting the Europa as a tow plane. Has it been done?
Wlad
Sent with Mailsuite · Unsubscribe
16/02/25, 14:16:13
[img]https://mailtrack.io/trace/mail/c086bd3711a7372b421126b5a8b61ad8d93dccd6.png?u=5817579[/img]
dmac7
PostPosted: Mon Feb 17, 2025 9:36 am    Post subject: Re: Europa as a tow plane? Reply with quote
The Europa mono has been used as a tow plane ex Walter Binder built a Classic Europa monowheel with many mods, such as fuel tanks in the wings, a XS style tailwheel before Europa did it and flaps independent from gear, but yes he used it for towing gliders too. He is in Germany.
erichdtrombley(at)juno.co
PostPosted: Tue Feb 18, 2025 6:05 am    Post subject: Europa as a tow plane? Reply with quote
Alan,
As mentioned, Walter Binder has done it. I had an opportunity to meet with him some 25 years ago and took several photos of his unique plane. As a result, I subsequently fabricated my own design for retractable outriggers and extended baggage bay, well before the XS was introduced. Walter allowed me to take all the pictures I wanted, but was tight lipped on the design/construction of his various modifications. Of course my German wasn’t very good either. If you are interested, I can see about resurrecting them.
Erich Trombley
N28ET
Classic Monowheel
914 with E-Props Glorieuse CS
PostPosted: Tue Feb 18, 2025 7:34 am    Post subject: Europa as a tow plane? Reply with quote
Eric, I will not be fitting a hook but I would be interested in retractable outriggers.
Alan
On 18 Feb 2025, at 14:06, Erich Trombley <erichdtrombley(at)juno.com> wrote:
Alan,
Erich Trombley
N28ET
Classic Monowheel
