		| Author | Message |
		| glipaz
				|  Posted: Fri Jul 05, 2024 6:29 pm    Post subject: Prop adjustment M-14p |   |
				| Asking the smarties on here.
I fly a Nanchang with a stock M-14p motor and an MT 250 prop.  When I push the nose down my RPMs increase without touching the prop lever.
 Assuming the governor is set up properly, if my RPMs increase when I go downhill would it be a spring issue in the governor?
 Gil
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| Ttail
				|  Posted: Fri Jul 05, 2024 8:28 pm    Post subject: Re: Prop adjustment M-14p |   |
				| Presuming you have the "Stronger" spring GiL.
 I previously had an MT250 fitted as well even with the Stronger spring it exhibited a little of this behaviour.
 I now have a 265cm MC400C from Whirlwind aviation fitted it still exhibits a little of this.
 (BTW IMO the Whirlwind prop in formation (Straight and form aeros) is a dramatic improvement over the previously fitted MT prop, and far more robust in rain etc)
 Sean Trestrail
 ttail[at]internode.on.net
		| Back to top |  |
		| glipaz
				|  Posted: Fri Jul 05, 2024 8:52 pm    Post subject: Re: Prop adjustment M-14p |   |
				| Yes, I sent the governor to MT for a stronger spring.
		| Back to top |  |
