Posted: Mon Oct 09, 2023 11:28 am Post subject: 3-phase current monitor |
See if the attached suggests a path toward your
design goals for monitoring 3-dynamo health:
See also https://www.sparkfun.com/datasheets/BreakoutBoards/0712.pdf
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
 Download |
| Filename: |
Three_Phase_Current_Monitor.pdf |
99.84 KB |
| Downloaded: |
530 Time(s) |
Eric Page
Posted: Mon Oct 09, 2023 12:48 pm Post subject: Re: 3-phase current monitor |
How funny -- we were both working on this at the same time.
Here's what I came up with. LED is off under normal ops and illuminates if a phase goes missing.
-Eric
 Download |
| Filename: |
Missing Phase Detector.pdf |
25.17 KB |
| Downloaded: |
447 Time(s) |
finn.lassen(at)verizon.ne Guest
Posted: Mon Oct 09, 2023 5:00 pm Post subject: 3-phase current monitor |
Interesting device. $3.79 each at DigiKey. Amazing that with boards and connectors only $3.33 ea. on Amazon.
Tempted to insert in paths to my fuse blocks and alternator field, but would introduce additional possible points of failure.
Finn
On 10/9/2023 3:28 PM, Robert L. Nuckolls, III wrote:
| Quote: | See if the attached suggests a path toward your
(o o)
Posted: Mon Oct 09, 2023 5:57 pm Post subject: 3-phase current monitor |
At 08:00 PM 10/9/2023, you wrote:
| Quote: | Interesting device. $3.79 each at DigiKey. Amazing that with boards and
connectors only $3.33 ea. on Amazon. |
Yeah, an they come already MOUNTED in
a form factor the DIY fabricator can
work with. Those 8-pin, SOIC chips and
associated board layouts are really
'fun' to work with!
I've got some coming to fiddle with a bit
before I forward them on to you to evaluate
in your DIY DAS project.
| Quote: | | Tempted to insert in paths to my fuse blocks and alternator field, but would introduce additional possible points of failure. |
Yeah . . . I think this is mostly an academic
exercise than a practical solution for
a 'problem' with very small probability of
occurrence -and- easily noted by other
instrumentation that should already be
in the airplane.
The most useful of in-flight monitors for
electrical system the low voltage warning
light. It that light is OUT, then probability
of comfortable completion of flight is
good.
The other bells-n-whistles are best
reserved for figuring why the light is
on AFTER landing whether or not they're
on the panel or in your toolbox.
(o o)
Posted: Tue Oct 10, 2023 11:04 am Post subject: Re: 3-phase current monitor |
Alternator problems such as loosing one phase or a diode failure result in a
higher AC component of the DC output. Based on that, perhaps something
like the circuit below connected to an EFIS input will warn if the AC
component is higher than a normal setpoint. If the signal is too weak, it
could be amplified. Is this idea feasible?
2.03 KB |
5949 Time(s) |
_________________ Joe Gores |
