Clouddog
Posted: Wed Aug 23, 2023 5:50 am Post subject: Replacing the rubber Grommet in the Air port |
I can't relate to the filler port but in other situations, I put the rubber grommet in very hot water to get it more flexible, a little silicone grease on it and work it in. I have used this on the prop hub, and during rebuilding of brake valves etc. where you run across the same tight fit. Good luck
Greg
On Tue, Aug 22, 2023, 23:07 Ttail <ttail(at)internode.on.net (ttail(at)internode.on.net)> wrote:
| Quote: | --> Yak-List message posted by: "Ttail" <ttail(at)internode.on.net (ttail(at)internode.on.net)>
Has anyone replaced the rubber grommet in the Air fill port ? I have the new rubber grommet. If so any tips om how you get the wider diameter base into a smaller diameter hole on the fitting itself ?
Sean Trestrail
ttail[at]internode.on.net
http://forums.matronics.com/viewtopic.php?p=511319#511319
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
billlang(at)live.com.au Guest
Posted: Wed Aug 23, 2023 4:01 pm Post subject: Replacing the rubber Grommet in the Air port |
KY
Bill Lang
0245731877
0416061877
| Quote: | On 23 Aug 2023, at 14:09, Ttail <ttail(at)internode.on.net> wrote:
Sean Trestrail
Ttail
