Simple sequencing using common 5-pin auto relays
alec(at)alecmyers.com
PostPosted: Wed Aug 09, 2023 7:39 am    Post subject: Simple sequencing using common 5-pin auto relays Reply with quote
This is prime territory for an 8-bit PIC microcontroller. Code that is only 30 lines long is easy to test, and the hardware already exists in the billions.
On Aug 9, 2023, at 11:22, Gilles T <gilles.thesee(at)free.fr> wrote:
Le 09/08/2023 à 17:09, Matthew S. Whiting a écrit :
Well, when every firing of your spark plugs and fuel injectors is running off a computer, I am not too worried about the computer controlling a couple of simple functions at engine start. Smile
As long as your chips are as robust, redundant and proved as theirs and you performed the same amount of tests and failure mode analyses Wink
Best regards
Gilles
http://contrails.free.fr
