charlesdavis(at)iuncapped Guest
Posted: Sat Aug 05, 2023 9:31 am Post subject: Motor reversing circuit for trim servo motor using automoti |
Bob, could you share some details on the actuator and how you
implemented the fit, please .... I need to achieve something similar to
this for a Whisper TMG.
Thanks, Charles
On 31/07/23 07:12 pm, Bob Verwey wrote:
I have converted a Luscombe manual trim to work with a linear actuator. 12v.
Momentary rocker switch on control stick.
While the internet abounds with circuit offerings, I am aware of
potential "noise" elements and there are probably a few best practices
to adhere to.
Any circuit suggestions appreciated.
Best...
Bob V
bob.verwey(at)gmail.com Guest
Posted: Mon Aug 07, 2023 9:21 am Post subject: Motor reversing circuit for trim servo motor using automoti |
This is a well tested solution on LSA airplanes in our part of the world.
Small trimtab makes it unlikely that a runaway event or mechanical disconnect will lead to catastrophic failure. Furthermore, these airplanes are for day VFR use only.
The unit is a simple 2 wire system and robust, with internal travel limit switches.
[img]cid:ii_ll14yjzy0[/img]
On Mon, 7 Aug 2023 at 01:55, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 12:31 PM 8/5/2023, you wrote:
| Quote: | --> AeroElectric-List message posted by: Charles Davis <charlesdavis(at)iuncapped.co.za (charlesdavis(at)iuncapped.co.za)>
Bob, could you share some details on the actuator and how you implemented the fit, please .... I need to achieve something similar to this for a Whisper TMG.
Thanks, Charles |
I've not been involved in crafting such an
installation in a light plane. I have worked
on controls and components for trim actuator
systems from Lear 55 down thru numerous light planes.
I've had failure analysis tasks on several
trim systems and I'm familiar with some
of the requirements and risks.
When I read that someone is considering or
has accomplished a modification to a design
with a demonstrated or certified history,
little red flags pop up. Just be sure that
the proposed system won't cut the stabilizer
or tabs loose to flop in the breeze.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
Best Regards,Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
1.6 MB |
2264 Time(s) |
