dlm34077(at)gmail.com Guest
Lenny Iszak
Posted: Sun Jun 25, 2023 10:04 am Post subject: oil seep |
Could be a broken oil diaphragm in the fuel pump.
Check out this pump teardown from Dan's site:
https://www.danhorton.net/VAF/High%20Fuel%20Pressure/Fuel%20Pump%20Dismantled.docx
The oil sump holds 12 qts in the D4A5, per Lycoming specs. The excess oil would just come out the breather.
Lenny
On Sun, Jun 25, 2023 at 1:36 PM dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:
| Quote: | Recently new oil and filter installed on IO540 D4A5. We added about 9.5 quarts on the stick.During the annual we opened and serviced (SB) the magnetos. We checked the strainer and removed/replaced the quick drain. We opened and closed five items.- These all check negative for seeps. Yet after seven days uncowled in the hangar, oil continues to seep slowly externally down the fuel pump drain line. I have also checked oil return lines. We are beginning to believe we may have overfilled the oil system. Any feedback from others?
Virus-free.www.avast.com[url=#m_1223495995127093501_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Sun Jun 25, 2023 10:39 am Post subject: oil seep |
In 13 year and 1,300 hours I've never put more than 7 quarts in mine.
Don
On Sunday, June 25, 2023 at 01:17:36 PM CDT, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
Lenny
_________________ Don A. McDonald
40636 |
