How reliable is Factory Europa Fuel sender?
rparigoris
PostPosted: Fri Feb 10, 2023 7:22 pm    Post subject: How reliable is Factory Europa Fuel sender? Reply with quote
Hi Group
We have a Europa Fuel sender on our mono. We had UMA build a nice fuel gauge with warning for the 9 positions. Range is .4 ohms empty and 190.7 ohms when full.
I never quite understood how the 9 positions worked.
Bill Daniels was kind enough to send me his old fuel gauge and sender. I figured if mine failed I would have a spare. How easy! Well of course instead of building aeroplane tonight, I had to test it and make sure it was working well. NOT!! Ended up it wouldn't read much below 1/2 tank and had some flakiness going on on the way up to full, or down from full.
Can't have that. So managed to get it apart from the top and began troubleshooting. Think Applied Archaic Technology here, 1950s to be exact when you think of old original computer core memory. Well if it was good enough to get Apollo to the moon, it should be good enough to operate a Europoa Fuel gauge. But this one failed?
OK here's how Europa designed it: they used special reed switches with what I suspect has a magnetic polarity, then they put a ferrite core on the outside of the reed switch. Now when the float that has magnets passes by the reed switch on the way to empty, it latches the reed switch to close the contacts and it stays closed because the polarity of the ferrite core is opposite that of the reed switch! Then when it passes on the way up to full, it reverses the polarity of the ferrite core and the switch opens. Each reed switch has a resistor across the terminals. Thus when you start opening the reed switches, you start adding the resistance together.
OK now what happened:
It appears that a rapid epoxy was used to hold the ferrite core to the glass reed switch. The position of the ferrite core is incredibly critical. Ends up the rapid epoxy is not a good choice as it failed and a number of them slid down due to gravity and stopped latching.
I was able to tune them using a very mild magnet to get position optimized where they would easily latch and unlatch. Then when using the float magnets, they work really well. Instead of rapid epoxy, I used some non stink silicone to hold cores in position.
Bottom line it now works great and I figured out how the thing works and I now have a spare.
It seems unless who ever fabricated the fuel sender changed adhesive, they are at risk to go flaky.
Figured i would share.
Europa figured into the sender the shape of the fuel tank so they position the reed switches at 1/8 tank increments. When doing the repair I could see see the different spacing.
Ron P.
MEE
PostPosted: Sat Feb 11, 2023 11:48 am    Post subject: Re: How reliable is Factory Europa Fuel sender? Reply with quote
Well done on the repair. I had to replace mine with a capacitance system.
Think it’s a RED probe and MGL gauge. Probe had to be adaptered to fit. Works well.
Ian McClelland
rparigoris
PostPosted: Sat Feb 11, 2023 12:05 pm    Post subject: Re: How reliable is Factory Europa Fuel sender? Reply with quote
Hi MEE
So your Europa Factory fuel sender went bad? What were the symptoms? About how old and how many hours?
Thx. Ron P.
MEE
PostPosted: Sun Feb 12, 2023 8:35 pm    Post subject: Re: How reliable is Factory Europa Fuel sender? Reply with quote
Indicated range progressively reduced till it only read 1/2 full.
It's about 12 years old.
Ian McClelland
