M-14P with electric start
easy_driver
PostPosted: Sat Dec 17, 2022 4:14 pm    Post subject: M-14P with electric start Reply with quote
curios if somebody on this list can help.
the owner of Yak i'm working on wants to add electric start. he bought a second hand set but the plate connecting starter mount to the front of the gearbox is missing so i have to machine it.
a good picture is all i need. unfortunately romanians or their rep would not help unless they profit.
richard.goode(at)russiana
PostPosted: Sun Dec 18, 2022 1:46 am    Post subject: M-14P with electric start Reply with quote
It isn't quite that simple unless you have all the necessary parts. Firstly you need a special propeller shaft with longer studs to accommodate the starter motor ring-gear. Then of course the ring gear itself. And it is not simply a plate but a more complex machined adapter for the starter motor mounting. We make them with Aerometal, our partner in Hungary, but I'm afraid they are on holiday until January 2 so I can't get a photograph until then. But if you could send me an email I will get Aerometal to make a couple of photographs for you. Richard.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN SOVIET & CHINESE RADIAL AIRCRAFT ENGINES
In partnership with Aerometal Kft, Hungary.
