Oil pressure gauge wiring ?
woodja51
PostPosted: Mon Aug 29, 2022 12:47 pm    Post subject: Oil pressure gauge wiring ? Reply with quote
Does anyone have the correct wiring sequence for the oil pressure gauges? I was trying to swap out a faulty transducer but the new one has thin pins compared to the old one. And trying to match the pins seems problematic as the numbers don’t match. My question is , and I’m assuming here one pin is ground , one is volts +24-28 and the other is the signal .. pins are numbered 1,2,3 in one plug , but not in the other. I’ve tried to find a wiring plan but undiscovered as yet … it’s probably a really simple standard. Any advice ? Matt
