Mono wheel bearings
Fokkerjockey
PostPosted: Sat Oct 08, 2016 2:40 am    Post subject: Mono wheel bearings Reply with quote
Would anyone happen to know the OEM part number or dimensions for the two bearings fitted to the original Ivan Shaw Aluminium wheel.
houlihan(at)blueyonder.co
PostPosted: Sat Oct 08, 2016 3:00 am    Post subject: Mono wheel bearings Reply with quote
The bearing type is shown on the build manual , knowing that you can get one at any bearing supplier, but why not via the Europa factory ?
On 08 October 2016 at 11:40 Fokkerjockey <M.giudici(at)ntlworld.com> wrote:
--> Europa-List message posted by: "Fokkerjockey" <M.giudici(at)ntlworld.com>
http://forums.matronics.com/viewtopic.php?p=461088#461088
PostPosted: Sat Oct 08, 2016 3:06 am    Post subject: Mono wheel bearings Reply with quote
Just for info it is shown as a KLNJ 1 1/2 or 60082rs
see http://www.europa-aircraft.biz/upload/cmb_29m_landinggear_mono.pdf
On 08 October 2016 at 11:59 houlihan tim <houlihan(at)blueyonder.co.uk> wrote:
<br==================>
nigel_graham(at)m-tecque.
PostPosted: Sat Oct 08, 2016 4:53 am    Post subject: Mono wheel bearings Reply with quote
OD: 2.625"
Width: 0.5625"
Part Number: 9R24
Fokkerjockey
PostPosted: Sat Oct 08, 2016 8:05 am    Post subject: Re: Mono wheel bearings Reply with quote
Thank you all for quick replies. I had gleamed the 9r24 number from the bearing itself however it is not recognised by the suppliers even though it is a standard Japanese bearing. Will try the other one from the build manual.
As for purchasing from Europa, that's always an option.
IanGale
PostPosted: Thu Aug 18, 2022 12:46 am    Post subject: Re: Mono wheel bearings Reply with quote
Thanks for these measurements - the builder manual gives a choice of bearings but one of them leads to a metric sized bearing which is definitely wrong. The sizes above are spot on, thank you
 Filesize:  31.1 KB
 Viewed:  6840 Time(s)
Area-51
PostPosted: Thu Aug 18, 2022 1:00 am    Post subject: Re: Mono wheel bearings Reply with quote
Over the past 40 years experience has shown that Koyo or Timken equally make the best quality longest lasting bearings; worth the extra dollars...
freddythek10(at)gmail.com
PostPosted: Fri Aug 19, 2022 2:25 pm    Post subject: Mono wheel bearings Reply with quote
Dwayne…your note is a bit mystifying in that I’ve made no search for new bearings of any kind…Fred
On Aug 18, 2022, at 7:15 AM, dmac7 <dmac7(at)outlook.com> wrote:
Hello Fred, if you want you are welcome to have my old bearings only 150 hours on em, I'm going to Victoria this weekend and could bring em along that's not so far from your island right?
Dwayne McAllister
http://forums.matronics.com/viewtopic.php?p=507699#507699
dmac7
PostPosted: Fri Aug 19, 2022 4:48 pm    Post subject: Re: Mono wheel bearings Reply with quote
Hi Fred,
You caught me! It was early in the morning, eyes hardly open and I mistakenly thought you were looking for a wheel bearing. I deleted post when I saw my mistake. My old bearings are for anyone who wants em! My bad
