Need another source or brand of 26 location HD D-Sub Connect
chaskuss(at)yahoo.com
PostPosted: Sat Jun 04, 2022 2:12 pm    Post subject: Need another source or brand of 26 location HD D-Sub Connect Reply with quote
I need to locate and purchase a single board mount 26 location, board mount, right angle female D-Sub connector. Mouser shows what I need as
https://www.mouser.com/ProductDetail/CONEC/15-007623?qs=lc2O%252BfHJPVZqz3A0P8yWLA%3D%3D
However, it's not a stocked item and they require a minimum 30 unit purchase to order it.. I found a stocking source, but they are in Germany. Might someone be able to help me find one closer?
https://www.elpro.org/gb/conec-15-0076slim-con-series/240135-15-007623.html
I'm hoping that a similar item may be manufactured by another company. Lack of the "threaded insert" mounting is not a deal breaker, as the current item is mounted to the circuit board simply by the 26 soldered pins.
Charlie K.
